Controlling spindle speed on SiegX2 with 0-10v analogue on MX3660 output SOLVED
03 May 2019 08:08 #132609 by antona
HI All
I'm just trying to use all the functionality of my Leadshine MX3660 which controls my Sieg X2p mini mill. One of the things I would like is to have spindle speed, direction and on/off controlled by Linuxcnc rather than manually. I have three inputs spare which I am going to hook up to a rotary encoder for feedback and speed but what I really want to know about is how to use the analogue 0-10v out on the MX3660 to control the speed.
The manual potentiometer seems to be 0-4.7V and there is a switch (well connector for a switch) in the mills control box that you flip for forwards and reverse (I think a relay hooked up to an output would do forward reverse). So as the manual potentiometer is 0-4.7 volts I wondered how I can utilise the 0-10v to run it? Can I connect it direct with a voltage decreaser? Do I need seperate circuit boards? little machine shop in America do a unit for $125 ( here )but just wondering if an easy fix is on hand using cheaper components.
Cheers
Jools
Attachments contain photos of my power boards ..
03 May 2019 10:16 - 03 May 2019 10:18 #132613 by Clive S
Strange that this post is similar to this one forum.linuxcnc.org/38-general-linuxcnc-q...utput-solved?start=0
But with a new op.:laugh:
Last edit: 03 May 2019 10:18 by Clive S.
  • InMyDarkestHour
  • InMyDarkestHour's Avatar
  • Visitor
  • Visitor
03 May 2019 23:08 #132673 by InMyDarkestHour
It is the same, even signed off with the previous OP's name.
Me thinks this is a spammer.
Mayhaps we will see a few more posts such as this then the posts for discounted name brand goods.
