new to linuxCNC; issues with updating and installing software
- lear
04 May 2019 02:22 #132682
by lear
new to linuxCNC; issues with updating and installing software was created by lear
Hi All,
I've been having a lot of trouble working with the build of Debian Wheezy that is part of the recommended install for LinuxCNC. Whenever I try to run sudo apt-get update or install any kind of program/software, I get 404 errors from repositories and some files fail to download. This seems to be specifically happening with the Debian repositories, but I'm too inexperienced with Linux to know how to fix it. Any help or recommendations on where to look would be greatly appreciated.
Thanks!
Thanks!
- Thank you received: 1472
04 May 2019 03:33 #132689
Replied by Todd Zuercher on topic new to linuxCNC; issues with updating and installing software
Now that Wheezy is eol, you need to change your repository list to point to Debian archives.
deb http://archive.debian.org/debian wheezy main
The following user(s) said Thank You: lear
- InMyDarkestHour
- Visitor
04 May 2019 04:59 #132694
by InMyDarkestHour
Replied by InMyDarkestHour on topic new to linuxCNC; issues with updating and installing software
- Thank you received: 4652
04 May 2019 17:44 #132758
Replied by andypugh on topic new to linuxCNC; issues with updating and installing software
If you are just starting then use this ISO image instead.
www.linuxcnc.org/testing-stretch-rtpreempt/
- lear
04 May 2019 21:13 #132771
by lear
Replied by lear on topic new to linuxCNC; issues with updating and installing software
Thanks for the help all! This fixed the issue
Time to create page: 0.307 seconds
