Disable or exit halcmd in Terminal
- pl7i92
- Thank you received: 358
07 May 2019 06:52 #133031
by pl7i92
Disable or exit halcmd in Terminal was created by pl7i92
Hi
if i did some research with halcmd in a terminal i cand start linuxcnc as posX is running
how do i get rid of the halcmd in terminal
OR How do i general exit halcmd in terminal
- gaston48
- Thank you received: 5
07 May 2019 08:51 #133037
by gaston48
Replied by gaston48 on topic Disable or exit halcmd in Terminal
Hello
" halcmd: exit "
" halcmd: exit "
- pl7i92
07 May 2019 09:06 #133038
by pl7i92
Replied by pl7i92 on topic Disable or exit halcmd in Terminal
did check that but linuxcnc wont start after that
as posx interpreter still running
- Thank you received: 4652
07 May 2019 18:52 #133077
Replied by andypugh on topic Disable or exit halcmd in Terminal
If LinuxCNC is already running:
halcmd -kf
Will connect you in to the running instance.
If LinuxCNC is nt running then
halrun
Will start realtime and give you a prompt.
I don't think that LinuxCNC will then run, though.
halrun -U
Should clear up a halcmd session.
halcmd -kf
halrun
halrun -U
Time to create page: 0.215 seconds
