EMC Crashing before starting
- komi89
07 May 2019 10:16 - 07 May 2019 18:54 #133044
by komi89
EMC Crashing before starting was created by komi89
Received the following error about a couple of days ago. Can anybody guide on what to do ? ThanksDebug file information:
.Kernel message information:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0
Machine configuration directory is '/home/okuma/linuxcnc/configs/by_interface.vitalsystems'
Machine configuration file is 'motenc.ini'
INIFILE=/home/okuma/linuxcnc/configs/by_interface.vitalsystems/motenc.ini
PARAMETER_FILE=motenc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_servo.hal
Found file(REL): ./motenc_motion.hal
Killing task linuxcncsvr, PID=12743
Removing NML shared memory segments.
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_motenc.ko: No such device
./motenc_motion.hal:4: exit value: 1
./motenc_motion.hal:4: insmod for hal_motenc failed, returned -1
See the output of 'dmesg' for more information.
12743
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components000
[ 0.419569] pci 0000:00:02.0: reg 10: [mem 0xfe800000-0xfebfffff 64bit]
[ 0.419569] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.419569] pci 0000:00:02.0: reg 20: [io 0xec90-0xec97]
[ 0.419569] pci 0000:00:02.1: [8086:2e13] type 00 class 0x038000
[ 0.419569] pci 0000:00:02.1: reg 10: [mem 0xfe700000-0xfe7fffff 64bit]
[ 0.419569] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.419569] pci 0000:00:03.0: reg 10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.419569] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.419569] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.419569] pci 0000:00:03.2: reg 10: [io 0xfe80-0xfe87]
[ 0.419569] pci 0000:00:03.2: reg 14: [io 0xfe90-0xfe93]
[ 0.419569] pci 0000:00:03.2: reg 18: [io 0xfea0-0xfea7]
[ 0.419569] pci 0000:00:03.2: reg 1c: [io 0xfeb0-0xfeb3]
[ 0.419569] pci 0000:00:03.2: reg 20: [io 0xfef0-0xfeff]
[ 0.419569] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.419569] pci 0000:00:03.3: reg 10: [io 0xec98-0xec9f]
[ 0.419569] pci 0000:00:03.3: reg 14: [mem 0xfe6d8000-0xfe6d8fff]
[ 0.419569] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.419569] pci 0000:00:19.0: reg 10: [mem 0xfe6e0000-0xfe6fffff]
[ 0.419569] pci 0000:00:19.0: reg 14: [mem 0xfe6d9000-0xfe6d9fff]
[ 0.419569] pci 0000:00:19.0: reg 18: [io 0xecc0-0xecdf]
[ 0.419569] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.419569] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.419569] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.419569] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.419569] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.419569] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.419569] pci 0000:00:1a.2: reg 20: [io 0xfc00-0xfc1f]
[ 0.419569] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.419569] pci 0000:00:1a.7: reg 10: [mem 0xfe6da000-0xfe6da3ff]
[ 0.419569] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.419569] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.419569] pci 0000:00:1b.0: reg 10: [mem 0xfe6dc000-0xfe6dffff 64bit]
[ 0.419569] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.419569] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.419569] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.419569] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.419569] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.419569] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.419569] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.419569] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.419569] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.419569] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.419569] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.419569] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.420041] pci 0000:00:1d.7: reg 10: [mem 0xff980000-0xff9803ff]
[ 0.420109] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.420129] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.420180] pci 0000:00:1f.0: [8086:3a1a] type 00 class 0x060100
[ 0.420281] pci 0000:00:1f.2: [8086:3a02] type 00 class 0x010601
[ 0.420298] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.420305] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.420312] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.420320] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.420327] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfedf]
[ 0.420334] pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9707ff]
[ 0.420364] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.420381] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.420395] pci 0000:00:1f.3: reg 10: [mem 0xfe6db000-0xfe6db0ff 64bit]
[ 0.420414] pci 0000:00:1f.3: reg 20: [io 0xece0-0xecff]
[ 0.420459] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.420463] pci 0000:00:01.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 0.420500] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.420505] pci 0000:00:1c.0: bridge window [mem 0xfe400000-0xfe4fffff]
[ 0.420543] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.420548] pci 0000:00:1c.1: bridge window [mem 0xfe300000-0xfe3fffff]
[ 0.420606] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.420615] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.420617] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.420619] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.420621] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
[ 0.420624] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.420626] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfec00000] (subtractive decode)
[ 0.420628] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff] (subtractive decode)
[ 0.420630] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff] (subtractive decode)
[ 0.420632] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
[ 0.420635] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
[ 0.420637] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff] (subtractive decode)
[ 0.420652] pci_bus 0000:00: on NUMA node 0
[ 0.420655] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.421325] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.421750] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.421960] ACPI Warning: For \_SB_.PCI0.PCI2._PRT: Return Package has no elements (empty) (20120320/nspredef-463)
[ 0.422012] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
[ 0.422327] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.422712] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 2.290725] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 2.291490] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 2.292268] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 2.293044] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 2.293801] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 2.294566] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 2.295338] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 2.296101] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 2.296336] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 2.296336] vgaarb: loaded
[ 2.296336] vgaarb: bridge control possible 0000:00:02.0
[ 2.296336] PCI: Using ACPI for IRQ routing
[ 2.301808] PCI: pci_cache_line_size set to 64 bytes
[ 2.301819] pci 0000:00:03.0: no compatible bridge window for [mem 0xfeda6000-0xfeda600f 64bit]
[ 2.301849] pci 0000:00:1f.2: no compatible bridge window for [mem 0xff970000-0xff9707ff]
[ 2.301886] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 2.301889] reserve RAM buffer: 000000000009e400 - 000000000009ffff
[ 2.301891] reserve RAM buffer: 000000007bbffc00 - 000000007bffffff
[ 2.302006] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 2.302014] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 2.304027] Switching to clocksource hpet
[ 2.304144] pnp: PnP ACPI init
[ 2.304144] ACPI: bus type pnp registered
[ 2.313275] pnp 00:00: [bus 00-ff]
[ 2.313278] pnp 00:00: [io 0x0cf8-0x0cff]
[ 2.313280] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 2.313282] pnp 00:00: [io 0x0d00-0xffff window]
[ 2.313284] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 2.313286] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 2.313288] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 2.313290] pnp 00:00: [mem 0xf0000000-0xfec00000 window]
[ 2.313294] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 2.313296] pnp 00:00: [mem 0xf0000000-0xefffffff window disabled]
[ 2.313298] pnp 00:00: [mem 0xff980000-0xff980fff window]
[ 2.313300] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 2.313302] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 2.313304] pnp 00:00: [mem 0xfeda7000-0xfeda7fff window]
[ 2.313332] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 2.317152] pnp 00:01: [io 0x0060]
[ 2.317154] pnp 00:01: [io 0x0064]
[ 2.317156] pnp 00:01: [io 0x0062-0x0063]
[ 2.317158] pnp 00:01: [io 0x0065-0x006f]
[ 2.317160] pnp 00:01: [io 0x00e0-0x00ef]
[ 2.317161] pnp 00:01: [io 0x0800-0x085f]
[ 2.317163] pnp 00:01: [io 0x0c00-0x0c7f]
[ 2.317165] pnp 00:01: [io 0x0860-0x08ff]
[ 2.317205] system 00:01: [io 0x0800-0x085f] has been reserved
[ 2.317208] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 2.317210] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 2.317213] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 2.317487] pnp 00:02: [io 0x0080-0x009f]
[ 2.317489] pnp 00:02: [io 0x0000-0x001f]
[ 2.317490] pnp 00:02: [io 0x00c0-0x00df]
[ 2.317493] pnp 00:02: [dma 4]
[ 2.317515] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 2.317727] pnp 00:03: [io 0x00f0-0x00ff]
[ 2.317734] pnp 00:03: [irq 13]
[ 2.317755] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 2.317956] pnp 00:04: [io 0x0061]
[ 2.317977] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 2.318189] pnp 00:05: [io 0x0070-0x007f]
[ 2.318193] pnp 00:05: [irq 8]
[ 2.318216] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 2.332796] pnp 00:06: [io 0x0378-0x037f]
[ 2.332798] pnp 00:06: [io 0x0778-0x077f]
[ 2.332802] pnp 00:06: [irq 7]
[ 2.332804] pnp 00:06: [dma 0 disabled]
[ 2.333995] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 2.339177] pnp 00:07: [io 0x03f8-0x03ff]
[ 2.339182] pnp 00:07: [irq 4]
[ 2.339579] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 2.354972] pnp 00:08: [mem 0xfed00000-0xfed003ff]
[ 2.355002] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
[ 2.355010] pnp: PnP ACPI: found 9 devices
[ 2.355011] ACPI: ACPI bus type pnp unregistered
[ 2.355014] PnPBIOS: Disabled by ACPI PNP
[ 2.391372] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 2.391375] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 2.391383] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 2.391386] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 2.391397] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.391400] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.391402] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.391405] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.391409] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref]
[ 2.391412] pci 0000:00:1c.1: BAR 15: assigned [mem 0xf0200000-0xf03fffff 64bit pref]
[ 2.391414] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.391417] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 2.391419] pci 0000:00:1f.2: BAR 5: assigned [mem 0xf0400000-0xf04007ff]
[ 2.391424] pci 0000:00:03.0: BAR 0: assigned [mem 0xf0400800-0xf040080f 64bit]
[ 2.391431] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 2.391435] pci 0000:00:01.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 2.391439] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 2.391442] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 2.391446] pci 0000:00:1c.0: bridge window [mem 0xfe400000-0xfe4fffff]
[ 2.391450] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf01fffff 64bit pref]
[ 2.391455] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 2.391458] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 2.391462] pci 0000:00:1c.1: bridge window [mem 0xfe300000-0xfe3fffff]
[ 2.391466] pci 0000:00:1c.1: bridge window [mem 0xf0200000-0xf03fffff 64bit pref]
[ 2.391471] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 2.391505] pci 0000:00:1e.0: setting latency timer to 64
[ 2.391509] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 2.391511] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 2.391513] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 2.391515] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff]
[ 2.391517] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff]
[ 2.391519] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfec00000]
[ 2.391521] pci_bus 0000:00: resource 10 [mem 0x80000000-0xdfffffff]
[ 2.391523] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff]
[ 2.391525] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff]
[ 2.391527] pci_bus 0000:00: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 2.391529] pci_bus 0000:00: resource 14 [mem 0xfeda7000-0xfeda7fff]
[ 2.391531] pci_bus 0000:01: resource 1 [mem 0xfe500000-0xfe5fffff]
[ 2.391533] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 2.391535] pci_bus 0000:02: resource 1 [mem 0xfe400000-0xfe4fffff]
[ 2.391537] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref]
[ 2.391539] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 2.391541] pci_bus 0000:03: resource 1 [mem 0xfe300000-0xfe3fffff]
[ 2.391543] pci_bus 0000:03: resource 2 [mem 0xf0200000-0xf03fffff 64bit pref]
[ 2.391545] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 2.391547] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 2.391549] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 2.391551] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff]
[ 2.391553] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff]
[ 2.391555] pci_bus 0000:04: resource 9 [mem 0xf0000000-0xfec00000]
[ 2.391557] pci_bus 0000:04: resource 10 [mem 0x80000000-0xdfffffff]
[ 2.391559] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff]
[ 2.391561] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff]
[ 2.391563] pci_bus 0000:04: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 2.391565] pci_bus 0000:04: resource 14 [mem 0xfeda7000-0xfeda7fff]
[ 2.391622] NET: Registered protocol family 2
[ 2.391679] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 2.391820] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.392094] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.392219] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.392221] TCP: reno registered
[ 2.392223] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.392229] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.392300] NET: Registered protocol family 1
[ 2.392313] pci 0000:00:02.0: Boot video device
[ 2.392505] PCI: CLS 64 bytes, default 64
[ 2.392540] Unpacking initramfs...
[ 2.614903] Freeing initrd memory: 14260k freed
[ 2.620221] Simple Boot Flag at 0x7a set to 0x1
[ 2.620610] audit: initializing netlink socket (disabled)
[ 2.620625] type=2000 audit(1289633261.616:1): initialized
[ 2.629588] highmem bounce pool size: 64 pages
[ 2.629593] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.629745] VFS: Disk quotas dquot_6.5.2
[ 2.629768] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.629834] msgmni has been set to 1722
[ 2.629979] alg: No test for stdrng (krng)
[ 2.630003] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.630006] io scheduler noop registered
[ 2.630008] io scheduler deadline registered
[ 2.630022] io scheduler cfq registered (default)
[ 2.630225] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.630240] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.630242] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.630776] GHES: HEST is not enabled!
[ 2.630785] isapnp: Scanning for PnP cards...
[ 2.983594] isapnp: No Plug & Play device found
[ 2.983644] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.003993] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 3.024575] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 3.044733] 0000:00:03.3: ttyS1 at I/O 0xec98 (irq = 17) is a 16550A
[ 3.045059] Linux agpgart interface v0.103
[ 3.045163] agpgart-intel 0000:00:00.0: Intel Q45/Q43 Chipset
[ 3.045211] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 3.045980] agpgart-intel 0000:00:00.0: detected 32768K stolen memory
[ 3.046085] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 3.046196] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 3.048939] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.048964] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.049050] mousedev: PS/2 mouse device common for all mice
[ 3.049089] rtc_cmos 00:05: RTC can wake from S4
[ 3.049193] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 3.049215] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 3.049322] TCP: cubic registered
[ 3.049367] NET: Registered protocol family 10
[ 3.049552] Mobile IPv6
[ 3.049554] NET: Registered protocol family 17
[ 3.049558] Registering the dns_resolver key type
[ 3.049606] Using IPI No-Shortcut mode
[ 3.049689] PM: Hibernation image not present or could not be loaded.
[ 3.049699] registered taskstats version 1
[ 3.050029] rtc_cmos 00:05: setting system clock to 2010-11-13 07:27:42 UTC (1289633262)
[ 3.050109] Freeing unused kernel memory: 416k freed
[ 3.050242] Write protecting the kernel text: 3496k
[ 3.050260] Write protecting the kernel read-only data: 984k
[ 3.058651] udevd[49]: starting version 175
[ 3.068550] usbcore: registered new interface driver usbfs
[ 3.068573] usbcore: registered new interface driver hub
[ 3.072442] usbcore: registered new device driver usb
[ 3.072830] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.072889] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 3.072893] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 3.072917] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 3.072945] ehci_hcd 0000:00:1a.7: debug port 1
[ 3.081706] SCSI subsystem initialized
[ 3.088251] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 3.088254] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 3.090087] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 3.090109] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfe6da000
[ 3.090352] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.093143] microcode: CPU0 sig=0x1067a, pf=0x1, revision=0xa07
[ 3.093702] libata version 3.00 loaded.
[ 3.100115] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 3.100140] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.100143] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.100145] usb usb1: Product: EHCI Host Controller
[ 3.100147] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 3.100148] usb usb1: SerialNumber: 0000:00:1a.7
[ 3.101099] hub 1-0:1.0: USB hub found
[ 3.101103] hub 1-0:1.0: 6 ports detected
[ 3.101212] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 3.101215] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 3.101223] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 3.101248] ehci_hcd 0000:00:1d.7: debug port 1
[ 3.105128] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 3.105151] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980000
[ 3.116018] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 3.116064] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.116067] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.116069] usb usb2: Product: EHCI Host Controller
[ 3.116070] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 3.116072] usb usb2: SerialNumber: 0000:00:1d.7
[ 3.116171] hub 2-0:1.0: USB hub found
[ 3.116175] hub 2-0:1.0: 6 ports detected
[ 3.116529] e1000e 0000:00:19.0: setting latency timer to 64
[ 3.116579] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 3.124007] microcode: CPU0 updated to revision 0xa0b, date = 2010-09-28
[ 3.125214] microcode: CPU1 sig=0x1067a, pf=0x1, revision=0xa07
[ 3.130909] microcode: CPU1 updated to revision 0xa0b, date = 2010-09-28
[ 3.131547] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 3.316087] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:23:ae:a6:8e:b1
[ 3.316090] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 3.316122] e1000e 0000:00:19.0: eth0: MAC: 8, PHY: 8, PBA No: 8021FF-0FF
[ 3.316153] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 3.316156] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 3.316166] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 3.316198] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 3.316228] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.316230] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.316232] usb usb3: Product: UHCI Host Controller
[ 3.316234] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.316235] usb usb3: SerialNumber: 0000:00:1a.0
[ 3.316325] hub 3-0:1.0: USB hub found
[ 3.316329] hub 3-0:1.0: 2 ports detected
[ 3.316402] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 3.316405] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 3.316411] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 3.316438] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 3.316464] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.316466] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.316468] usb usb4: Product: UHCI Host Controller
[ 3.316470] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.316472] usb usb4: SerialNumber: 0000:00:1a.1
[ 3.316549] hub 4-0:1.0: USB hub found
[ 3.316553] hub 4-0:1.0: 2 ports detected
[ 3.316620] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 3.316623] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 3.316628] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 3.316650] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 3.316676] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.316679] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.316680] usb usb5: Product: UHCI Host Controller
[ 3.316682] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.316684] usb usb5: SerialNumber: 0000:00:1a.2
[ 3.316763] hub 5-0:1.0: USB hub found
[ 3.316768] hub 5-0:1.0: 2 ports detected
[ 3.316839] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 3.316841] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.316847] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 3.316867] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 3.316893] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.316895] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.316897] usb usb6: Product: UHCI Host Controller
[ 3.316899] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.316901] usb usb6: SerialNumber: 0000:00:1d.0
[ 3.316976] hub 6-0:1.0: USB hub found
[ 3.316979] hub 6-0:1.0: 2 ports detected
[ 3.317044] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.317047] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.317055] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 3.317075] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 3.317101] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.317104] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.317105] usb usb7: Product: UHCI Host Controller
[ 3.317107] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.317109] usb usb7: SerialNumber: 0000:00:1d.1
[ 3.317184] hub 7-0:1.0: USB hub found
[ 3.317188] hub 7-0:1.0: 2 ports detected
[ 3.317253] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.317256] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.317262] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 3.317289] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 3.317315] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.317317] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.317319] usb usb8: Product: UHCI Host Controller
[ 3.317321] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.317323] usb usb8: SerialNumber: 0000:00:1d.2
[ 3.317398] hub 8-0:1.0: USB hub found
[ 3.317403] hub 8-0:1.0: 2 ports detected
[ 3.317508] ata_generic 0000:00:03.2: setting latency timer to 64
[ 3.318840] scsi0 : ata_generic
[ 3.318996] scsi1 : ata_generic
[ 3.319034] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 3.319037] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 3.319068] ahci 0000:00:1f.2: version 3.0
[ 3.319149] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x23 impl SATA mode
[ 3.319152] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ems sxs
[ 3.319156] ahci 0000:00:1f.2: setting latency timer to 64
[ 3.332565] scsi2 : ahci
[ 3.332828] scsi3 : ahci
[ 3.332893] scsi4 : ahci
[ 3.332953] scsi5 : ahci
[ 3.333013] scsi6 : ahci
[ 3.333073] scsi7 : ahci
[ 3.334581] ata3: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400100 irq 18
[ 3.334584] ata4: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400180 irq 18
[ 3.334586] ata5: DUMMY
[ 3.334587] ata6: DUMMY
[ 3.334589] ata7: DUMMY
[ 3.334591] ata8: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400380 irq 18
[ 3.620016] Refined TSC clocksource calibration: 3058.999 MHz.
[ 3.620023] Switching to clocksource tsc
[ 3.628022] usb 6-2: new low-speed USB device number 2 using uhci_hcd
[ 3.652021] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.652514] ata4.00: ATAPI: TSSTcorp DVD+/-RW TS-H653G, D200, max UDMA/100
[ 3.652519] ata4.00: applying bridge limits
[ 3.653209] ata4.00: configured for UDMA/100
[ 3.656017] ata8: SATA link down (SStatus 0 SControl 300)
[ 3.656035] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.699990] ata3.00: ATA-7: ST3160815AS, 3.ADA, max UDMA/133
[ 3.699994] ata3.00: 312500000 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 3.758292] ata3.00: configured for UDMA/133
[ 3.758456] scsi 2:0:0:0: Direct-Access ATA ST3160815AS 3.AD PQ: 0 ANSI: 5
[ 3.759082] scsi 3:0:0:0: CD-ROM TSSTcorp DVD+-RW TS-H653G D200 PQ: 0 ANSI: 5
[ 3.763618] sd 2:0:0:0: [sda] 312500000 512-byte logical blocks: (160 GB/149 GiB)
[ 3.763663] sd 2:0:0:0: [sda] Write Protect is off
[ 3.763665] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.763684] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.803907] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[ 3.803912] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.803917] usb 6-2: Product: USB KB V11
[ 3.803920] usb 6-2: Manufacturer: GASIA
[ 3.824353] sda: sda1 sda2 < sda5 >
[ 3.824689] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.826220] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 3.826253] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 3.827271] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.827275] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.827420] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 3.830296] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input0
[ 3.830445] generic-usb 0003:0E8F:0022.0001: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[ 3.857036] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input1
[ 3.857094] generic-usb 0003:0E8F:0022.0002: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[ 3.857113] usbcore: registered new interface driver usbhid
[ 3.857114] usbhid: USB HID core driver
[ 4.364017] usb 8-1: new low-speed USB device number 2 using uhci_hcd
[ 4.533329] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[ 4.533334] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.533337] usb 8-1: Product: USB OPTICAL MOUSE
[ 4.551757] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input2
[ 4.551819] generic-usb 0003:0000:0538.0003: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[ 9.184707] PM: Starting manual resume from disk
[ 9.184711] PM: Hibernation image partition 8:5 present
[ 9.184712] PM: Looking for hibernation image.
[ 9.184879] PM: Image not found (code -22)
[ 9.184882] PM: Hibernation image not present or could not be loaded.
[ 9.215598] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.186569] udevd[359]: starting version 175
[ 11.382128] wmi: Mapper loaded
[ 11.648663] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 11.648670] ACPI: Power Button [VBTN]
[ 11.648727] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 11.648730] ACPI: Power Button [PWRF]
[ 11.653117] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 11.804306] input: Dell WMI hotkeys as /devices/virtual/input/input5
[ 11.945977] [drm] Initialized drm 1.1.0 20060810
[ 12.137702] parport_pc 00:06: reported by Plug and Play ACPI
[ 12.137755] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 12.208990] iTCO_vendor_support: vendor-support=0
[ 12.259848] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 12.259930] iTCO_wdt: Found a ICH10D TCO device (Version=2, TCOBASE=0x0860)
[ 12.260101] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.444990] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[ 12.446750] i915 0000:00:02.0: setting latency timer to 64
[ 12.457100] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 12.457103] [drm] Driver supports precise vblank timestamp query.
[ 12.457137] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 12.522957] fbcon: inteldrmfb (fb0) is primary device
[ 12.562737] Console: switching to colour frame buffer device 128x48
[ 12.564757] fb0: inteldrmfb frame buffer device
[ 12.564758] drm: registered panic notifier
[ 12.564792] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 14.066262] Adding 4051964k swap on /dev/sda5. Priority:-1 extents:1 across:4051964k
[ 14.075959] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 14.265050] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.350021] loop: module loaded
[ 15.375619] RPC: Registered named UNIX socket transport module.
[ 15.375622] RPC: Registered udp transport module.
[ 15.375623] RPC: Registered tcp transport module.
[ 15.375625] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.411981] FS-Cache: Loaded
[ 15.436441] NFS: Registering the id_resolver key type
[ 15.436458] FS-Cache: Netfs 'nfs' registered for caching
[ 15.450587] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.404326] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7
[ 19.154802] Bluetooth: Core ver 2.16
[ 19.154814] NET: Registered protocol family 31
[ 19.154816] Bluetooth: HCI device and connection manager initialized
[ 19.154818] Bluetooth: HCI socket layer initialized
[ 19.154820] Bluetooth: L2CAP socket layer initialized
[ 19.154824] Bluetooth: SCO socket layer initialized
[ 19.198685] Bluetooth: RFCOMM TTY layer initialized
[ 19.198690] Bluetooth: RFCOMM socket layer initialized
[ 19.198691] Bluetooth: RFCOMM ver 1.11
[ 19.537915] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.537918] Bluetooth: BNEP filters: protocol multicast
[ 19.696612] lp0: using parport0 (interrupt-driven).
[ 19.784546] ppdev: user-space parallel port driver
[ 20.523014] ADDRCONF(NETDEV_UP): eth0: link is not ready
[55939.544056] usb 8-1: USB disconnect, device number 2
[55939.924016] usb 8-1: new low-speed USB device number 3 using uhci_hcd
[55940.093985] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[55940.093990] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[55940.093994] usb 8-1: Product: USB OPTICAL MOUSE
[55940.112428] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input8
[55940.112520] generic-usb 0003:0000:0538.0004: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[55991.696084] I-pipe: head domain RTAI registered.
[55991.696088] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[55991.696111] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[55991.696114] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[55991.696116] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[55991.696118] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16582250
[55991.738565] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[55991.738589] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[55991.738593] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[55991.738595] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[55991.738597] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[55991.751040] RTAI[math]: loaded.
[55994.384271] RTAI[math]: unloaded.
[55994.385441] SCHED releases registered named ALIEN PEDV$D
[55994.389165] RTAI[malloc]: unloaded.
[55994.488023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[55994.489326] I-pipe: head domain RTAI unregistered.
[55994.489357] RTAI[hal]: unmounted.
[56019.515537] I-pipe: head domain RTAI registered.
[56019.515542] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56019.515566] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56019.515569] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56019.515572] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56019.515574] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 14404000
[56019.521126] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56019.521150] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56019.521153] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56019.521156] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56019.521158] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56019.529444] RTAI[math]: loaded.
[56021.802802] RTAI[math]: unloaded.
[56021.803924] SCHED releases registered named ALIEN PEDV$D
[56021.807965] RTAI[malloc]: unloaded.
[56021.904014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56021.905305] I-pipe: head domain RTAI unregistered.
[56021.905333] RTAI[hal]: unmounted.
[56058.088044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[56058.088052] usb 6-2: USB disconnect, device number 2
[56058.576017] usb 6-2: new low-speed USB device number 3 using uhci_hcd
[56058.751590] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[56058.751595] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56058.751599] usb 6-2: Product: USB KB V11
[56058.751602] usb 6-2: Manufacturer: GASIA
[56058.769022] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input9
[56058.769090] generic-usb 0003:0E8F:0022.0005: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[56058.800714] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input10
[56058.800804] generic-usb 0003:0E8F:0022.0006: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[56100.248070] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[56100.248078] usb 6-2: USB disconnect, device number 3
[56100.508019] usb 6-2: new low-speed USB device number 4 using uhci_hcd
[56100.683601] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[56100.683606] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56100.683610] usb 6-2: Product: USB KB V11
[56100.683613] usb 6-2: Manufacturer: GASIA
[56100.701025] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input11
[56100.701093] generic-usb 0003:0E8F:0022.0007: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[56100.733722] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input12
[56100.733840] generic-usb 0003:0E8F:0022.0008: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[56214.080048] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[56214.080055] usb 8-1: USB disconnect, device number 3
[56214.324016] usb 8-1: new low-speed USB device number 4 using uhci_hcd
[56214.549052] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[56214.549056] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[56214.549060] usb 8-1: Product: USB OPTICAL MOUSE
[56214.567485] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input13
[56214.567608] generic-usb 0003:0000:0538.0009: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[56230.944072] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[56230.944079] usb 6-2: USB disconnect, device number 4
[56231.200017] usb 6-2: new low-speed USB device number 5 using uhci_hcd
[56231.375633] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[56231.375637] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56231.375642] usb 6-2: Product: USB KB V11
[56231.375645] usb 6-2: Manufacturer: GASIA
[56231.393059] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input14
[56231.393132] generic-usb 0003:0E8F:0022.000A: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[56231.424758] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input15
[56231.424862] generic-usb 0003:0E8F:0022.000B: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[56240.120074] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[56240.120082] usb 6-2: USB disconnect, device number 5
[56240.372019] usb 6-2: new low-speed USB device number 6 using uhci_hcd
[56240.547635] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[56240.547641] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56240.547645] usb 6-2: Product: USB KB V11
[56240.547648] usb 6-2: Manufacturer: GASIA
[56240.565062] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input16
[56240.565130] generic-usb 0003:0E8F:0022.000C: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[56240.597758] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input17
[56240.597870] generic-usb 0003:0E8F:0022.000D: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[56320.217631] I-pipe: head domain RTAI registered.
[56320.217635] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56320.217659] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56320.217661] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56320.217664] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56320.217666] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15848250
[56320.223321] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56320.223345] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56320.223348] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56320.223351] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56320.223353] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56320.229992] RTAI[math]: loaded.
[56322.520663] RTAI[math]: unloaded.
[56322.521779] SCHED releases registered named ALIEN PEDV$D
[56322.525690] RTAI[malloc]: unloaded.
[56322.624014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56322.625357] I-pipe: head domain RTAI unregistered.
[56322.625387] RTAI[hal]: unmounted.
[56336.158111] I-pipe: head domain RTAI registered.
[56336.158115] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56336.158140] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56336.158143] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56336.158145] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56336.158148] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15840750
[56336.163658] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56336.163682] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56336.163686] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56336.163688] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56336.163690] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56336.167286] RTAI[math]: loaded.
[56338.541304] RTAI[math]: unloaded.
[56338.542487] SCHED releases registered named ALIEN PEDV$D
[56338.546204] RTAI[malloc]: unloaded.
[56338.644017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56338.645384] I-pipe: head domain RTAI unregistered.
[56338.645411] RTAI[hal]: unmounted.
[56350.629981] I-pipe: head domain RTAI registered.
[56350.629985] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56350.630009] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56350.630012] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56350.630014] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56350.630016] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15889000
[56350.636951] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56350.636975] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56350.636979] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56350.636981] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56350.636983] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56350.642737] RTAI[math]: loaded.
[56353.033363] RTAI[math]: unloaded.
[56353.034484] SCHED releases registered named ALIEN PEDV$D
[56353.037066] RTAI[malloc]: unloaded.
[56353.136017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56353.137381] I-pipe: head domain RTAI unregistered.
[56353.137409] RTAI[hal]: unmounted.
[56560.393882] I-pipe: head domain RTAI registered.
[56560.393886] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56560.393909] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56560.393912] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56560.393915] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56560.393917] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16340250
[56560.399454] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56560.399477] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56560.399481] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56560.399483] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56560.399485] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56560.403591] RTAI[math]: loaded.
[56562.777033] RTAI[math]: unloaded.
[56562.778208] SCHED releases registered named ALIEN PEDV$D
[56562.779960] RTAI[malloc]: unloaded.
[56562.876013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56562.877305] I-pipe: head domain RTAI unregistered.
[56562.877333] RTAI[hal]: unmounted.
[56587.262629] I-pipe: head domain RTAI registered.
[56587.262633] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56587.262656] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56587.262659] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56587.262661] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56587.262663] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15316750
[56587.268339] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56587.268363] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56587.268367] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56587.268370] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56587.268371] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56587.273473] RTAI[math]: loaded.
[56589.643932] RTAI[math]: unloaded.
[56589.645060] SCHED releases registered named ALIEN PEDV$D
[56589.649515] RTAI[malloc]: unloaded.
[56589.748020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56589.749336] I-pipe: head domain RTAI unregistered.
[56589.749364] RTAI[hal]: unmounted.
[56625.140283] I-pipe: head domain RTAI registered.
[56625.140287] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56625.140316] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56625.140319] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56625.140321] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56625.140324] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16596250
[56625.145811] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56625.145835] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56625.145838] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56625.145841] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56625.145842] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56625.149413] RTAI[math]: loaded.
[56627.524229] RTAI[math]: unloaded.
[56627.525406] SCHED releases registered named ALIEN PEDV$D
[56627.529496] RTAI[malloc]: unloaded.
[56627.628014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56627.629293] I-pipe: head domain RTAI unregistered.
[56627.629324] RTAI[hal]: unmounted.
[56632.220506] I-pipe: head domain RTAI registered.
[56632.220510] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56632.220532] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56632.220535] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56632.220537] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56632.220540] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16589500
[56632.226284] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56632.226307] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56632.226310] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56632.226313] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56632.226315] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56632.230008] RTAI[math]: loaded.
[56634.599558] RTAI[math]: unloaded.
[56634.600684] SCHED releases registered named ALIEN PEDV$D
[56634.604914] RTAI[malloc]: unloaded.
[56634.704016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56634.705303] I-pipe: head domain RTAI unregistered.
[56634.705334] RTAI[hal]: unmounted.
[56652.830776] I-pipe: head domain RTAI registered.
[56652.830780] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56652.830809] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56652.830812] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56652.830814] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56652.830817] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15234500
[56652.836478] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56652.836500] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56652.836504] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56652.836507] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56652.836508] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56652.840165] RTAI[math]: loaded.
[56655.219873] RTAI[math]: unloaded.
[56655.221002] SCHED releases registered named ALIEN PEDV$D
[56655.225498] RTAI[malloc]: unloaded.
[56655.324016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56655.325337] I-pipe: head domain RTAI unregistered.
[56655.325364] RTAI[hal]: unmounted.
[56695.597662] I-pipe: head domain RTAI registered.
[56695.597667] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56695.597691] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56695.597694] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56695.597696] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56695.597699] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16098500
[56695.603249] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56695.603272] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56695.603276] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56695.603278] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56695.603280] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56695.609985] RTAI[math]: loaded.
[56706.972137] RTAI[math]: unloaded.
[56706.973305] SCHED releases registered named ALIEN PEDV$D
[56706.975137] RTAI[malloc]: unloaded.
[56707.072015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56707.073580] I-pipe: head domain RTAI unregistered.
[56707.073607] RTAI[hal]: unmounted.
[56829.946038] I-pipe: head domain RTAI registered.
[56829.946042] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[56829.946066] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[56829.946069] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[56829.946071] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[56829.946073] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15740500
[56829.951735] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[56829.951757] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[56829.951760] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[56829.951763] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[56829.951765] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[56829.958023] RTAI[math]: loaded.
[56832.241091] RTAI[math]: unloaded.
[56832.242267] SCHED releases registered named ALIEN PEDV$D
[56832.245726] RTAI[malloc]: unloaded.
[56832.344017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[56832.345353] I-pipe: head domain RTAI unregistered.
[56832.345380] RTAI[hal]: unmounted.
[57308.504062] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[57308.504070] usb 6-2: USB disconnect, device number 6
[57308.756018] usb 6-2: new low-speed USB device number 7 using uhci_hcd
[57308.931896] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[57308.931901] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[57308.931905] usb 6-2: Product: USB KB V11
[57308.931909] usb 6-2: Manufacturer: GASIA
[57308.949320] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input18
[57308.949421] generic-usb 0003:0E8F:0022.000E: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[57308.982018] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input19
[57308.982131] generic-usb 0003:0E8F:0022.000F: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[58170.552063] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[58170.552071] usb 6-2: USB disconnect, device number 7
[58170.804019] usb 6-2: new low-speed USB device number 8 using uhci_hcd
[58170.979106] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[58170.979111] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[58170.979115] usb 6-2: Product: USB KB V11
[58170.979118] usb 6-2: Manufacturer: GASIA
[58170.996530] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input20
[58170.996600] generic-usb 0003:0E8F:0022.0010: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[58171.028228] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input21
[58171.028312] generic-usb 0003:0E8F:0022.0011: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[60425.120045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[60425.120053] usb 6-2: USB disconnect, device number 8
[60425.384021] usb 6-2: new low-speed USB device number 9 using uhci_hcd
[60425.559656] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[60425.559661] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[60425.559665] usb 6-2: Product: USB KB V11
[60425.559669] usb 6-2: Manufacturer: GASIA
[60425.577076] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input22
[60425.577183] generic-usb 0003:0E8F:0022.0012: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[60425.608779] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input23
[60425.608895] generic-usb 0003:0E8F:0022.0013: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[61299.112966] I-pipe: head domain RTAI registered.
[61299.112970] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[61299.112999] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[61299.113002] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[61299.113004] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[61299.113006] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16599750
[61299.118510] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[61299.118534] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[61299.118537] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[61299.118540] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[61299.118542] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[61299.128252] RTAI[math]: loaded.
[61301.417116] RTAI[math]: unloaded.
[61301.418272] SCHED releases registered named ALIEN PEDV$D
[61301.422318] RTAI[malloc]: unloaded.
[61301.520018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[61301.521395] I-pipe: head domain RTAI unregistered.
[61301.521426] RTAI[hal]: unmounted.
[61324.505390] I-pipe: head domain RTAI registered.
[61324.505394] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[61324.505418] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[61324.505421] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[61324.505423] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[61324.505426] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16605750
[61324.511137] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[61324.511160] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[61324.511164] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[61324.511166] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[61324.511168] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[61324.514807] RTAI[math]: loaded.
[61326.898998] RTAI[math]: unloaded.
[61326.900137] SCHED releases registered named ALIEN PEDV$D
[61326.901971] RTAI[malloc]: unloaded.
[61327.000018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[61327.001327] I-pipe: head domain RTAI unregistered.
[61327.001356] RTAI[hal]: unmounted.
[61415.277070] I-pipe: head domain RTAI registered.
[61415.277074] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[61415.277103] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[61415.277106] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[61415.277108] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[61415.277110] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16601250
[61415.283896] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[61415.283921] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[61415.283924] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[61415.283927] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[61415.283928] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[61415.287577] RTAI[math]: loaded.
[61417.667362] RTAI[math]: unloaded.
[61417.668545] SCHED releases registered named ALIEN PEDV$D
[61417.672233] RTAI[malloc]: unloaded.
[61417.772017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[61417.773323] I-pipe: head domain RTAI unregistered.
[61417.773351] RTAI[hal]: unmounted.
[64074.936051] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64074.936059] usb 6-2: USB disconnect, device number 9
[64075.248016] usb 6-2: new low-speed USB device number 10 using uhci_hcd
[64075.423547] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64075.423552] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64075.423556] usb 6-2: Product: USB KB V11
[64075.423559] usb 6-2: Manufacturer: GASIA
[64075.440980] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input24
[64075.441093] generic-usb 0003:0E8F:0022.0014: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64075.473668] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input25
[64075.473758] generic-usb 0003:0E8F:0022.0015: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[64443.960046] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64443.960054] usb 6-2: USB disconnect, device number 10
[64444.360016] usb 6-2: new low-speed USB device number 11 using uhci_hcd
[64444.535638] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64444.535644] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64444.535648] usb 6-2: Product: USB KB V11
[64444.535651] usb 6-2: Manufacturer: GASIA
[64444.553061] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input26
[64444.553132] generic-usb 0003:0E8F:0022.0016: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64444.585761] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input27
[64444.585879] generic-usb 0003:0E8F:0022.0017: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[64672.368043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64672.368051] usb 6-2: USB disconnect, device number 11
[64672.620020] usb 6-2: new low-speed USB device number 12 using uhci_hcd
[64672.795694] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64672.795699] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64672.795703] usb 6-2: Product: USB KB V11
[64672.795706] usb 6-2: Manufacturer: GASIA
[64672.813121] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input28
[64672.813229] generic-usb 0003:0E8F:0022.0018: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64672.844816] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input29
[64672.844921] generic-usb 0003:0E8F:0022.0019: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[64747.760039] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64747.760047] usb 6-2: USB disconnect, device number 12
[64748.096016] usb 6-2: new low-speed USB device number 13 using uhci_hcd
[64748.270712] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64748.270717] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64748.270721] usb 6-2: Product: USB KB V11
[64748.270724] usb 6-2: Manufacturer: GASIA
[64748.288148] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input30
[64748.288217] generic-usb 0003:0E8F:0022.001A: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64748.320834] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input31
[64748.320926] generic-usb 0003:0E8F:0022.001B: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[64781.488047] usb 8-1: USB disconnect, device number 4
[64781.860018] usb 8-1: new low-speed USB device number 5 using uhci_hcd
[64782.029144] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[64782.029149] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[64782.029153] usb 8-1: Product: USB OPTICAL MOUSE
[64782.047571] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input32
[64782.047696] generic-usb 0003:0000:0538.001C: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[64919.624044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64919.624052] usb 6-2: USB disconnect, device number 13
[64919.872031] usb 6-2: new low-speed USB device number 14 using uhci_hcd
[64920.047754] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64920.047759] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64920.047763] usb 6-2: Product: USB KB V11
[64920.047766] usb 6-2: Manufacturer: GASIA
[64920.065181] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input33
[64920.065250] generic-usb 0003:0E8F:0022.001D: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64920.097876] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input34
[64920.097989] generic-usb 0003:0E8F:0022.001E: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[64934.504049] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64934.504057] usb 6-2: USB disconnect, device number 14
[64934.756017] usb 6-2: new low-speed USB device number 15 using uhci_hcd
[64934.931757] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64934.931762] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64934.931766] usb 6-2: Product: USB KB V11
[64934.931770] usb 6-2: Manufacturer: GASIA
[64934.949183] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input35
[64934.949255] generic-usb 0003:0E8F:0022.001F: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64934.980880] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input36
[64934.980970] generic-usb 0003:0E8F:0022.0020: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[64988.320043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[64988.320051] usb 6-2: USB disconnect, device number 15
[64988.568031] usb 6-2: new low-speed USB device number 16 using uhci_hcd
[64988.743771] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[64988.743775] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[64988.743780] usb 6-2: Product: USB KB V11
[64988.743783] usb 6-2: Manufacturer: GASIA
[64988.761185] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input37
[64988.761256] generic-usb 0003:0E8F:0022.0021: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[64988.793892] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input38
[64988.794006] generic-usb 0003:0E8F:0022.0022: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65038.912043] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[65038.912051] usb 8-1: USB disconnect, device number 5
[65039.156016] usb 8-1: new low-speed USB device number 6 using uhci_hcd
[65039.325206] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65039.325212] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65039.325216] usb 8-1: Product: USB OPTICAL MOUSE
[65039.343644] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input39
[65039.343768] generic-usb 0003:0000:0538.0023: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65127.944046] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[65127.944054] usb 8-1: USB disconnect, device number 6
[65128.360016] usb 8-1: new low-speed USB device number 7 using uhci_hcd
[65128.529228] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65128.529233] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65128.529237] usb 8-1: Product: USB OPTICAL MOUSE
[65128.547668] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input40
[65128.547791] generic-usb 0003:0000:0538.0024: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65130.672045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65130.672053] usb 6-2: USB disconnect, device number 16
[65131.160016] usb 6-2: new low-speed USB device number 17 using uhci_hcd
[65131.335805] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65131.335810] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65131.335814] usb 6-2: Product: USB KB V11
[65131.335817] usb 6-2: Manufacturer: GASIA
[65131.353229] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input41
[65131.353341] generic-usb 0003:0E8F:0022.0025: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65131.385928] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input42
[65131.386031] generic-usb 0003:0E8F:0022.0026: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65153.488044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65153.488052] usb 6-2: USB disconnect, device number 17
[65153.860018] usb 6-2: new low-speed USB device number 18 using uhci_hcd
[65154.035811] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65154.035816] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65154.035820] usb 6-2: Product: USB KB V11
[65154.035824] usb 6-2: Manufacturer: GASIA
[65154.053236] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input43
[65154.053306] generic-usb 0003:0E8F:0022.0027: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65154.084936] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input44
[65154.085017] generic-usb 0003:0E8F:0022.0028: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65199.120048] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65199.120056] usb 6-2: USB disconnect, device number 18
[65199.368030] usb 6-2: new low-speed USB device number 19 using uhci_hcd
[65199.543822] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65199.543827] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65199.543831] usb 6-2: Product: USB KB V11
[65199.543834] usb 6-2: Manufacturer: GASIA
[65199.561251] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input45
[65199.561322] generic-usb 0003:0E8F:0022.0029: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65199.593944] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input46
[65199.594058] generic-usb 0003:0E8F:0022.002A: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65203.584045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65203.584053] usb 6-2: USB disconnect, device number 19
[65203.836017] usb 6-2: new low-speed USB device number 20 using uhci_hcd
[65204.011823] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65204.011828] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65204.011832] usb 6-2: Product: USB KB V11
[65204.011835] usb 6-2: Manufacturer: GASIA
[65204.029235] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input47
[65204.029306] generic-usb 0003:0E8F:0022.002B: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65204.060947] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input48
[65204.061035] generic-usb 0003:0E8F:0022.002C: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65327.088045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65327.088053] usb 6-2: USB disconnect, device number 20
[65327.336018] usb 6-2: new low-speed USB device number 21 using uhci_hcd
[65327.511853] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65327.511858] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65327.511862] usb 6-2: Product: USB KB V11
[65327.511865] usb 6-2: Manufacturer: GASIA
[65327.529280] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input49
[65327.529348] generic-usb 0003:0E8F:0022.002D: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65327.561973] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input50
[65327.562089] generic-usb 0003:0E8F:0022.002E: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65352.136044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65352.136052] usb 6-2: USB disconnect, device number 21
[65352.384031] usb 6-2: new low-speed USB device number 22 using uhci_hcd
[65352.559860] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65352.559865] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65352.559869] usb 6-2: Product: USB KB V11
[65352.559873] usb 6-2: Manufacturer: GASIA
[65352.577289] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input51
[65352.577398] generic-usb 0003:0E8F:0022.002F: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65352.609981] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input52
[65352.610070] generic-usb 0003:0E8F:0022.0030: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65515.816050] usb 8-1: USB disconnect, device number 7
[65516.552016] usb 8-1: new low-speed USB device number 8 using uhci_hcd
[65516.721322] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65516.721327] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65516.721332] usb 8-1: Product: USB OPTICAL MOUSE
[65516.739767] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input53
[65516.739893] generic-usb 0003:0000:0538.0031: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65630.144043] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[65630.144051] usb 8-1: USB disconnect, device number 8
[65630.860018] usb 8-1: new low-speed USB device number 9 using uhci_hcd
[65631.029350] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65631.029356] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65631.029360] usb 8-1: Product: USB OPTICAL MOUSE
[65631.047794] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input54
[65631.047889] generic-usb 0003:0000:0538.0032: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65773.240043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65773.240051] usb 6-2: USB disconnect, device number 22
[65773.516016] usb 6-2: new low-speed USB device number 23 using uhci_hcd
[65773.691962] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65773.691968] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65773.691972] usb 6-2: Product: USB KB V11
[65773.691975] usb 6-2: Manufacturer: GASIA
[65773.709386] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input55
[65773.709493] generic-usb 0003:0E8F:0022.0033: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65773.741086] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input56
[65773.741188] generic-usb 0003:0E8F:0022.0034: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[65938.160047] usb 8-1: USB disconnect, device number 9
[65938.504015] usb 8-1: new low-speed USB device number 10 using uhci_hcd
[65938.673426] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65938.673432] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65938.673436] usb 8-1: Product: USB OPTICAL MOUSE
[65938.691865] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input57
[65938.691988] generic-usb 0003:0000:0538.0035: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65944.856048] usb 8-1: USB disconnect, device number 10
[65945.200015] usb 8-1: new low-speed USB device number 11 using uhci_hcd
[65945.369428] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65945.369433] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65945.369437] usb 8-1: Product: USB OPTICAL MOUSE
[65945.387869] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input58
[65945.387966] generic-usb 0003:0000:0538.0036: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65987.016050] usb 8-1: USB disconnect, device number 11
[65987.752016] usb 8-1: new low-speed USB device number 12 using uhci_hcd
[65987.921438] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65987.921443] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65987.921447] usb 8-1: Product: USB OPTICAL MOUSE
[65987.939883] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input59
[65987.940017] generic-usb 0003:0000:0538.0037: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65990.188052] usb 8-1: USB disconnect, device number 12
[65990.436016] usb 8-1: new low-speed USB device number 13 using uhci_hcd
[65990.605438] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[65990.605444] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[65990.605448] usb 8-1: Product: USB OPTICAL MOUSE
[65990.623877] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input60
[65990.623998] generic-usb 0003:0000:0538.0038: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[65998.672044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[65998.672052] usb 6-2: USB disconnect, device number 23
[65999.164016] usb 6-2: new low-speed USB device number 24 using uhci_hcd
[65999.340019] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[65999.340024] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[65999.340028] usb 6-2: Product: USB KB V11
[65999.340031] usb 6-2: Manufacturer: GASIA
[65999.357441] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input61
[65999.357552] generic-usb 0003:0E8F:0022.0039: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[65999.389141] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input62
[65999.389246] generic-usb 0003:0E8F:0022.003A: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66002.144044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66002.144052] usb 6-2: USB disconnect, device number 24
[66002.468026] usb 6-2: new low-speed USB device number 25 using uhci_hcd
[66002.644020] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66002.644025] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66002.644029] usb 6-2: Product: USB KB V11
[66002.644033] usb 6-2: Manufacturer: GASIA
[66002.661452] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input63
[66002.661571] generic-usb 0003:0E8F:0022.003B: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66002.693142] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input64
[66002.693246] generic-usb 0003:0E8F:0022.003C: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66015.288045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66015.288053] usb 6-2: USB disconnect, device number 25
[66015.540017] usb 6-2: new low-speed USB device number 26 using uhci_hcd
[66015.699022] usb 6-2: unable to read config index 0 descriptor/all
[66015.699028] usb 6-2: can't read configurations, error -71
[66015.812016] usb 6-2: new low-speed USB device number 27 using uhci_hcd
[66015.988022] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66015.988027] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66015.988032] usb 6-2: Product: USB KB V11
[66015.988035] usb 6-2: Manufacturer: GASIA
[66016.005436] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input65
[66016.005506] generic-usb 0003:0E8F:0022.003D: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66016.037146] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input66
[66016.037234] generic-usb 0003:0E8F:0022.003E: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66078.280044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66078.280052] usb 6-2: USB disconnect, device number 27
[66078.552017] usb 6-2: new low-speed USB device number 28 using uhci_hcd
[66078.727036] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66078.727041] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66078.727045] usb 6-2: Product: USB KB V11
[66078.727048] usb 6-2: Manufacturer: GASIA
[66078.744465] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input67
[66078.744533] generic-usb 0003:0E8F:0022.003F: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66078.777159] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input68
[66078.777274] generic-usb 0003:0E8F:0022.0040: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66082.992045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66082.992053] usb 6-2: USB disconnect, device number 28
[66083.248016] usb 6-2: new low-speed USB device number 29 using uhci_hcd
[66083.423038] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66083.423043] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66083.423047] usb 6-2: Product: USB KB V11
[66083.423050] usb 6-2: Manufacturer: GASIA
[66083.440461] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input69
[66083.440567] generic-usb 0003:0E8F:0022.0041: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66083.473160] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input70
[66083.473246] generic-usb 0003:0E8F:0022.0042: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66102.832046] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66102.832054] usb 6-2: USB disconnect, device number 29
[66103.136017] usb 6-2: new low-speed USB device number 30 using uhci_hcd
[66103.368043] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66103.368049] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66103.368053] usb 6-2: Product: USB KB V11
[66103.368056] usb 6-2: Manufacturer: GASIA
[66103.385473] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input71
[66103.385543] generic-usb 0003:0E8F:0022.0043: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66103.418164] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input72
[66103.418278] generic-usb 0003:0E8F:0022.0044: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66221.624047] usb 8-1: USB disconnect, device number 13
[66222.360016] usb 8-1: new low-speed USB device number 14 using uhci_hcd
[66222.529495] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[66222.529500] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[66222.529504] usb 8-1: Product: USB OPTICAL MOUSE
[66222.547934] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input73
[66222.548040] generic-usb 0003:0000:0538.0045: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[66459.208045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66459.208053] usb 6-2: USB disconnect, device number 30
[66459.488016] usb 6-2: new low-speed USB device number 31 using uhci_hcd
[66459.663130] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66459.663136] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66459.663140] usb 6-2: Product: USB KB V11
[66459.663143] usb 6-2: Manufacturer: GASIA
[66459.680560] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input74
[66459.680632] generic-usb 0003:0E8F:0022.0046: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66459.713253] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input75
[66459.713345] generic-usb 0003:0E8F:0022.0047: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66786.072047] usb 8-1: USB disconnect, device number 14
[66786.360015] usb 8-1: new low-speed USB device number 15 using uhci_hcd
[66786.529633] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[66786.529638] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[66786.529642] usb 8-1: Product: USB OPTICAL MOUSE
[66786.548073] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input76
[66786.548194] generic-usb 0003:0000:0538.0048: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[66850.056042] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66850.056051] usb 6-2: USB disconnect, device number 31
[66850.360016] usb 6-2: new low-speed USB device number 32 using uhci_hcd
[66850.535225] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66850.535231] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66850.535235] usb 6-2: Product: USB KB V11
[66850.535238] usb 6-2: Manufacturer: GASIA
[66850.552440] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input77
[66850.552517] generic-usb 0003:0E8F:0022.0049: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66850.585350] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input78
[66850.585440] generic-usb 0003:0E8F:0022.004A: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66870.144043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[66870.144051] usb 6-2: USB disconnect, device number 32
[66870.392020] usb 6-2: new low-speed USB device number 33 using uhci_hcd
[66870.567230] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[66870.567235] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[66870.567240] usb 6-2: Product: USB KB V11
[66870.567243] usb 6-2: Manufacturer: GASIA
[66870.584660] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input79
[66870.584768] generic-usb 0003:0E8F:0022.004B: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[66870.617352] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input80
[66870.617445] generic-usb 0003:0E8F:0022.004C: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[66899.408043] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[66899.408051] usb 8-1: USB disconnect, device number 15
[66899.656016] usb 8-1: new low-speed USB device number 16 using uhci_hcd
[66899.825661] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[66899.825666] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[66899.825670] usb 8-1: Product: USB OPTICAL MOUSE
[66899.844092] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input81
[66899.844188] generic-usb 0003:0000:0538.004D: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[67165.512047] usb 8-1: USB disconnect, device number 16
[67165.760040] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67165.760048] usb 6-2: USB disconnect, device number 33
[67166.012021] usb 6-2: new low-speed USB device number 34 using uhci_hcd
[67166.187302] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67166.187307] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67166.187311] usb 6-2: Product: USB KB V11
[67166.187315] usb 6-2: Manufacturer: GASIA
[67166.204727] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input82
[67166.204795] generic-usb 0003:0E8F:0022.004E: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67166.237425] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input83
[67166.237508] generic-usb 0003:0E8F:0022.004F: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67166.476023] usb 8-1: new low-speed USB device number 17 using uhci_hcd
[67166.645725] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[67166.645730] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[67166.645734] usb 8-1: Product: USB OPTICAL MOUSE
[67166.664175] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input84
[67166.664271] generic-usb 0003:0000:0538.0050: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[67167.000047] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67167.000055] usb 6-2: USB disconnect, device number 34
[67167.256017] usb 6-2: new low-speed USB device number 35 using uhci_hcd
[67167.431306] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67167.431312] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67167.431316] usb 6-2: Product: USB KB V11
[67167.431319] usb 6-2: Manufacturer: GASIA
[67167.448731] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input85
[67167.448806] generic-usb 0003:0E8F:0022.0051: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67167.481424] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input86
[67167.481513] generic-usb 0003:0E8F:0022.0052: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67169.480050] usb 8-1: USB disconnect, device number 17
[67169.728031] usb 8-1: new low-speed USB device number 18 using uhci_hcd
[67169.897726] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[67169.897731] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[67169.897735] usb 8-1: Product: USB OPTICAL MOUSE
[67169.916175] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input87
[67169.916295] generic-usb 0003:0000:0538.0053: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[67215.112046] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67215.112054] usb 6-2: USB disconnect, device number 35
[67215.364017] usb 6-2: new low-speed USB device number 36 using uhci_hcd
[67215.539314] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67215.539319] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67215.539323] usb 6-2: Product: USB KB V11
[67215.539326] usb 6-2: Manufacturer: GASIA
[67215.556742] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input88
[67215.556813] generic-usb 0003:0E8F:0022.0054: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67215.589439] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input89
[67215.589525] generic-usb 0003:0E8F:0022.0055: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67355.232044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67355.232052] usb 6-2: USB disconnect, device number 36
[67355.504017] usb 6-2: new low-speed USB device number 37 using uhci_hcd
[67355.679349] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67355.679354] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67355.679359] usb 6-2: Product: USB KB V11
[67355.679362] usb 6-2: Manufacturer: GASIA
[67355.696781] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input90
[67355.696851] generic-usb 0003:0E8F:0022.0056: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67355.729468] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input91
[67355.729584] generic-usb 0003:0E8F:0022.0057: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67383.752043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67383.752051] usb 6-2: USB disconnect, device number 37
[67384.004023] usb 6-2: new low-speed USB device number 38 using uhci_hcd
[67384.179355] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67384.179360] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67384.179364] usb 6-2: Product: USB KB V11
[67384.179368] usb 6-2: Manufacturer: GASIA
[67384.196784] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input92
[67384.196855] generic-usb 0003:0E8F:0022.0058: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67384.229478] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input93
[67384.229562] generic-usb 0003:0E8F:0022.0059: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67428.144048] usb 8-1: USB disconnect, device number 18
[67428.632016] usb 8-1: new low-speed USB device number 19 using uhci_hcd
[67428.801789] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[67428.801794] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[67428.801799] usb 8-1: Product: USB OPTICAL MOUSE
[67428.820240] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input94
[67428.820335] generic-usb 0003:0000:0538.005A: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[67430.128045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67430.128053] usb 6-2: USB disconnect, device number 38
[67430.596016] usb 6-2: new low-speed USB device number 39 using uhci_hcd
[67430.771368] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67430.771374] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67430.771378] usb 6-2: Product: USB KB V11
[67430.771382] usb 6-2: Manufacturer: GASIA
[67430.788795] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input95
[67430.788870] generic-usb 0003:0E8F:0022.005B: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67430.821491] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input96
[67430.821573] generic-usb 0003:0E8F:0022.005C: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67463.608044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67463.608052] usb 6-2: USB disconnect, device number 39
[67463.860018] usb 6-2: new low-speed USB device number 40 using uhci_hcd
[67464.035374] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67464.035379] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67464.035384] usb 6-2: Product: USB KB V11
[67464.035387] usb 6-2: Manufacturer: GASIA
[67464.052802] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input97
[67464.052874] generic-usb 0003:0E8F:0022.005D: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67464.085498] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input98
[67464.085586] generic-usb 0003:0E8F:0022.005E: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67558.096044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67558.096052] usb 6-2: USB disconnect, device number 40
[67558.360016] usb 6-2: new low-speed USB device number 41 using uhci_hcd
[67558.535398] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67558.535403] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67558.535407] usb 6-2: Product: USB KB V11
[67558.535410] usb 6-2: Manufacturer: GASIA
[67558.552827] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input99
[67558.552896] generic-usb 0003:0E8F:0022.005F: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67558.585521] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input100
[67558.585632] generic-usb 0003:0E8F:0022.0060: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67565.536044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[67565.536052] usb 6-2: USB disconnect, device number 41
[67565.860018] usb 6-2: new low-speed USB device number 42 using uhci_hcd
[67566.035400] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[67566.035405] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[67566.035409] usb 6-2: Product: USB KB V11
[67566.035412] usb 6-2: Manufacturer: GASIA
[67566.052827] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input101
[67566.052899] generic-usb 0003:0E8F:0022.0061: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[67566.085524] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input102
[67566.085612] generic-usb 0003:0E8F:0022.0062: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[67566.528045] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[67566.528053] usb 8-1: USB disconnect, device number 19
[67566.776030] usb 8-1: new low-speed USB device number 20 using uhci_hcd
[67566.945824] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[67566.945829] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[67566.945833] usb 8-1: Product: USB OPTICAL MOUSE
[67566.964238] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input103
[67566.964360] generic-usb 0003:0000:0538.0063: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[67966.552044] hub 8-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[67966.552052] usb 8-1: USB disconnect, device number 20
[67966.860017] usb 8-1: new low-speed USB device number 21 using uhci_hcd
[67967.029922] usb 8-1: New USB device found, idVendor=0000, idProduct=0538
[67967.029927] usb 8-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[67967.029931] usb 8-1: Product: USB OPTICAL MOUSE
[67967.048372] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.2/usb8/8-1/8-1:1.0/input/input104
[67967.048470] generic-usb 0003:0000:0538.0064: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.2-1/input0
[68465.528045] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[68465.528053] usb 6-2: USB disconnect, device number 42
[68465.800016] usb 6-2: new low-speed USB device number 43 using uhci_hcd
[68465.975619] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[68465.975625] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[68465.975629] usb 6-2: Product: USB KB V11
[68465.975632] usb 6-2: Manufacturer: GASIA
[68465.993047] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input105
[68465.993116] generic-usb 0003:0E8F:0022.0065: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[68466.025741] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input106
[68466.025852] generic-usb 0003:0E8F:0022.0066: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[69314.184043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[69314.184051] usb 6-2: USB disconnect, device number 43
[69314.676016] usb 6-2: new low-speed USB device number 44 using uhci_hcd
[69314.851827] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[69314.851833] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[69314.851837] usb 6-2: Product: USB KB V11
[69314.851840] usb 6-2: Manufacturer: GASIA
[69314.869244] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input107
[69314.869316] generic-usb 0003:0E8F:0022.0067: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[69314.901950] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input108
[69314.902037] generic-usb 0003:0E8F:0022.0068: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[69918.626168] I-pipe: head domain RTAI registered.
[69918.626173] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[69918.626196] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[69918.626199] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[69918.626201] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[69918.626204] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15691250
[69918.631731] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[69918.631758] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[69918.631761] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[69918.631764] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[69918.631765] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[69918.641326] RTAI[math]: loaded.
[69921.024463] RTAI[math]: unloaded.
[69921.025589] SCHED releases registered named ALIEN PEDV$D
[69921.029271] RTAI[malloc]: unloaded.
[69921.128013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[69921.129319] I-pipe: head domain RTAI unregistered.
[69921.129346] RTAI[hal]: unmounted.
[69939.664984] I-pipe: head domain RTAI registered.
[69939.664988] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[69939.665012] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[69939.665014] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[69939.665017] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[69939.665019] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16603000
[69939.670767] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[69939.670791] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[69939.670795] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[69939.670797] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[69939.670799] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[69939.674530] RTAI[math]: loaded.
[69942.054218] RTAI[math]: unloaded.
[69942.055399] SCHED releases registered named ALIEN PEDV$D
[69942.060932] RTAI[malloc]: unloaded.
[69942.160017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[69942.161405] I-pipe: head domain RTAI unregistered.
[69942.161436] RTAI[hal]: unmounted.
[69978.259815] I-pipe: head domain RTAI registered.
[69978.259819] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[69978.259844] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[69978.259847] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[69978.259849] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[69978.259851] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15739500
[69978.265470] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[69978.265495] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[69978.265498] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[69978.265501] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[69978.265502] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[69978.271069] RTAI[math]: loaded.
[69980.662887] RTAI[math]: unloaded.
[69980.664054] SCHED releases registered named ALIEN PEDV$D
[69980.667693] RTAI[malloc]: unloaded.
[69980.764013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[69980.765311] I-pipe: head domain RTAI unregistered.
[69980.765340] RTAI[hal]: unmounted.
[70067.649766] I-pipe: head domain RTAI registered.
[70067.649770] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[70067.649799] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[70067.649802] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[70067.649804] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[70067.649807] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15728500
[70067.655431] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[70067.655454] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[70067.655457] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[70067.655460] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[70067.655462] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[70067.664910] RTAI[math]: loaded.
[70069.937431] RTAI[math]: unloaded.
[70069.938601] SCHED releases registered named ALIEN PEDV$D
[70069.942270] RTAI[malloc]: unloaded.
[70070.040017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[70070.041310] I-pipe: head domain RTAI unregistered.
[70070.041341] RTAI[hal]: unmounted.
[70146.102177] I-pipe: head domain RTAI registered.
[70146.102181] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[70146.102210] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[70146.102213] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[70146.102215] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[70146.102218] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15675250
[70146.107737] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[70146.107761] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[70146.107764] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[70146.107767] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[70146.107769] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[70146.111360] RTAI[math]: loaded.
[70148.491892] RTAI[math]: unloaded.
[70148.493064] SCHED releases registered named ALIEN PEDV$D
[70148.497012] RTAI[malloc]: unloaded.
[70148.596017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[70148.597379] I-pipe: head domain RTAI unregistered.
[70148.597405] RTAI[hal]: unmounted.
[70214.947438] I-pipe: head domain RTAI registered.
[70214.947442] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[70214.947466] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[70214.947469] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[70214.947471] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[70214.947474] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 14462750
[70214.953285] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[70214.953307] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[70214.953311] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[70214.953313] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[70214.953315] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[70214.957405] RTAI[math]: loaded.
[70217.331008] RTAI[math]: unloaded.
[70217.332134] SCHED releases registered named ALIEN PEDV$D
[70217.336235] RTAI[malloc]: unloaded.
[70217.436013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[70217.437311] I-pipe: head domain RTAI unregistered.
[70217.437339] RTAI[hal]: unmounted.
[70306.521470] I-pipe: head domain RTAI registered.
[70306.521475] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[70306.521504] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[70306.521507] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[70306.521509] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[70306.521512] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16603750
[70306.527152] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[70306.527174] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[70306.527178] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[70306.527180] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[70306.527182] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[70306.530868] RTAI[math]: loaded.
[70308.919670] RTAI[math]: unloaded.
[70308.920796] SCHED releases registered named ALIEN PEDV$D
[70308.924636] RTAI[malloc]: unloaded.
[70309.024018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[70309.025345] I-pipe: head domain RTAI unregistered.
[70309.025372] RTAI[hal]: unmounted.
[70476.560044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[70476.560052] usb 6-2: USB disconnect, device number 44
[70476.860018] usb 6-2: new low-speed USB device number 45 using uhci_hcd
[70477.035110] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[70477.035115] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[70477.035119] usb 6-2: Product: USB KB V11
[70477.035123] usb 6-2: Manufacturer: GASIA
[70477.052541] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input109
[70477.052618] generic-usb 0003:0E8F:0022.0069: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[70477.084233] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input110
[70477.084347] generic-usb 0003:0E8F:0022.006A: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[70790.197942] I-pipe: head domain RTAI registered.
[70790.197947] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[70790.197971] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[70790.197974] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[70790.197976] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[70790.197979] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16336000
[70790.203549] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[70790.203572] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[70790.203575] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[70790.203578] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[70790.203580] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[70790.210763] RTAI[math]: loaded.
[70792.504802] RTAI[math]: unloaded.
[70792.505984] SCHED releases registered named ALIEN PEDV$D
[70792.507722] RTAI[malloc]: unloaded.
[70792.604018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[70792.605381] I-pipe: head domain RTAI unregistered.
[70792.605408] RTAI[hal]: unmounted.
[70867.408043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[70867.408051] usb 6-2: USB disconnect, device number 45
[70867.860016] usb 6-2: new low-speed USB device number 46 using uhci_hcd
[70868.035205] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[70868.035210] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[70868.035214] usb 6-2: Product: USB KB V11
[70868.035218] usb 6-2: Manufacturer: GASIA
[70868.052640] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input111
[70868.052709] generic-usb 0003:0E8F:0022.006B: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[70868.084329] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input112
[70868.084438] generic-usb 0003:0E8F:0022.006C: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[70876.088043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[70876.088052] usb 6-2: USB disconnect, device number 46
[70876.340018] usb 6-2: new low-speed USB device number 47 using uhci_hcd
[70876.515208] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[70876.515214] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[70876.515218] usb 6-2: Product: USB KB V11
[70876.515222] usb 6-2: Manufacturer: GASIA
[70876.532635] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input113
[70876.532713] generic-usb 0003:0E8F:0022.006D: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[70876.564331] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input114
[70876.564440] generic-usb 0003:0E8F:0022.006E: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[70911.800044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[70911.800052] usb 6-2: USB disconnect, device number 47
[70912.052016] usb 6-2: new low-speed USB device number 48 using uhci_hcd
[70912.227216] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[70912.227222] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[70912.227226] usb 6-2: Product: USB KB V11
[70912.227229] usb 6-2: Manufacturer: GASIA
[70912.244644] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input115
[70912.244716] generic-usb 0003:0E8F:0022.006F: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[70912.276339] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input116
[70912.276433] generic-usb 0003:0E8F:0022.0070: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[71725.488043] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[71725.488051] usb 6-2: USB disconnect, device number 48
[71725.860017] usb 6-2: new low-speed USB device number 49 using uhci_hcd
[71726.035415] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[71726.035420] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[71726.035424] usb 6-2: Product: USB KB V11
[71726.035428] usb 6-2: Manufacturer: GASIA
[71726.052844] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input117
[71726.052913] generic-usb 0003:0E8F:0022.0071: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[71726.084538] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input118
[71726.084651] generic-usb 0003:0E8F:0022.0072: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[71752.520044] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[71752.520051] usb 6-2: USB disconnect, device number 49
[71752.860016] usb 6-2: new low-speed USB device number 50 using uhci_hcd
[71753.035422] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[71753.035428] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[71753.035432] usb 6-2: Product: USB KB V11
[71753.035435] usb 6-2: Manufacturer: GASIA
[71753.052850] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input119
[71753.052923] generic-usb 0003:0E8F:0022.0073: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[71753.084548] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input120
[71753.084659] generic-usb 0003:0E8F:0022.0074: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[72407.904606] I-pipe: head domain RTAI registered.
[72407.904610] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72407.904634] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72407.904637] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[72407.904639] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72407.904642] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16591750
[72407.910418] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72407.910441] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72407.910445] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[72407.910448] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[72407.910449] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72407.921592] RTAI[math]: loaded.
[72410.212436] RTAI[math]: unloaded.
[72410.213612] SCHED releases registered named ALIEN PEDV$D
[72410.215515] RTAI[malloc]: unloaded.
[72410.312015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72410.313402] I-pipe: head domain RTAI unregistered.
[72410.313434] RTAI[hal]: unmounted.
[72675.979787] I-pipe: head domain RTAI registered.
[72675.979791] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72675.979815] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72675.979818] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[72675.979820] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72675.979822] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15440750
[72675.985583] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72675.985606] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72675.985610] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[72675.985612] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[72675.985614] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72675.995235] RTAI[math]: loaded.
[72678.393978] RTAI[math]: unloaded.
[72678.395155] SCHED releases registered named ALIEN PEDV$D
[72678.398901] RTAI[malloc]: unloaded.
[72678.496014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72678.497298] I-pipe: head domain RTAI unregistered.
[72678.497325] RTAI[hal]: unmounted.
[72826.608046] hub 6-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[72826.608054] usb 6-2: USB disconnect, device number 50
[72826.868023] usb 6-2: new low-speed USB device number 51 using uhci_hcd
[72827.043685] usb 6-2: New USB device found, idVendor=0e8f, idProduct=0022
[72827.043691] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[72827.043695] usb 6-2: Product: USB KB V11
[72827.043698] usb 6-2: Manufacturer: GASIA
[72827.061114] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.0/input/input121
[72827.061191] generic-usb 0003:0E8F:0022.0075: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:00:1d.0-2/input0
[72827.092820] input: GASIA USB KB V11 as /devices/pci0000:00/0000:00:1d.0/usb6/6-2/6-2:1.1/input/input122
[72827.092942] generic-usb 0003:0E8F:0022.0076: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:00:1d.0-2/input1
[72828.378971] I-pipe: head domain RTAI registered.
[72828.378976] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72828.378998] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72828.379001] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[72828.379003] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72828.379006] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16458000
[72828.384704] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72828.384729] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72828.384733] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[72828.384735] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[72828.384737] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72828.395020] RTAI[math]: loaded.
[72830.707420] RTAI[math]: unloaded.
[72830.708542] SCHED releases registered named ALIEN PEDV$D
[72830.710500] RTAI[malloc]: unloaded.
[72830.808014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72830.809308] I-pipe: head domain RTAI unregistered.
[72830.809335] RTAI[hal]: unmounted.
[72851.581048] I-pipe: head domain RTAI registered.
[72851.581052] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[72851.581076] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[72851.581079] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 3059014000, CPU_FREQ 3059014000
[72851.581082] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[72851.581084] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16603500
[72851.586708] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[72851.586732] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[72851.586736] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[72851.586739] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3059014000 hz.
[72851.586740] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[72851.590398] RTAI[math]: loaded.
[72853.987034] RTAI[math]: unloaded.
[72853.988206] SCHED releases registered named ALIEN PEDV$D
[72853.991872] RTAI[malloc]: unloaded.
[72854.088013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[72854.089319] I-pipe: head domain RTAI unregistered.
[72854.089347] RTAI[hal]: unmounted.
Last edit: 07 May 2019 18:54 by andypugh.
- InMyDarkestHour
- Visitor
07 May 2019 12:30 #133049
by InMyDarkestHour
Replied by InMyDarkestHour on topic EMC Crashing before starting
What's the output of lspci ?
Your card is inserted correctly ? Have you tried reseating the card ?
The driver is trying to load but can't find the card.....
Probably not related.
Has the MB suffered or been connected during a power surge or is there a problem with your mouse or hub ?
- Thank you received: 4652
07 May 2019 18:55 #133079
Replied by andypugh on topic EMC Crashing before starting
Do you actually have a Motenc card?
(It seems likely that you do, my first guess was that you were loading a Motenc sample config by mistake)
Time to create page: 0.108 seconds
