LinuxCNC Cheating
10 May 2019 11:55 #133346 by Jocman
LinuxCNC Cheating was created by Jocman
Hi all.
I'm wondering if there's some way to cheat LinuxCNC so to use it without any parport, controller or CNC machine.
I mean, I've an old laptop wich is good to run LinuxCNC, and I'd like to use it during the lunch break (i.e) to test some modification to LinuxCNC (routines, custom GUI, etc), so to have some fun without destroying the "good" pc used with my CNC.
Andrea
10 May 2019 12:23 #133347 by rodw
Replied by rodw on topic LinuxCNC Cheating
Thats what the simulations are for that are included in the linuxcnc chooser window on startup.
  • InMyDarkestHour
  • InMyDarkestHour's Avatar
  • Visitor
  • Visitor
10 May 2019 13:58 - 10 May 2019 14:01 #133355 by InMyDarkestHour
Replied by InMyDarkestHour on topic LinuxCNC Cheating
Sometimes if people just RTFM hahahahahaha
Dnn't mind me I spent the whole day trying to prevent myself getting run over trying to stop others from injuring others, then on the way home had an altercation with some (insert sting of bad words here) muslim that tried to run over a flock of Cockatoos.
Last edit: 10 May 2019 14:01 by InMyDarkestHour.
10 May 2019 14:55 #133362 by Jocman
Replied by Jocman on topic LinuxCNC Cheating
Thanks, I'll give it a glance
10 May 2019 15:06 #133363 by pl7i92
Replied by pl7i92 on topic LinuxCNC Cheating
as you see it in my channel
Im the BIGGEST Cheeter as there is no mashine
YOU can even run it on a DVD with your MS PCmashine
10 May 2019 15:08 #133364 by Todd Zuercher
Replied by Todd Zuercher on topic LinuxCNC Cheating
I have several VMs installed with Linuxcnc that I experiment with.
14 May 2019 12:05 #133731 by andypugh
Replied by andypugh on topic LinuxCNC Cheating
Hi all.
You don't even need to cheat, a whole selection of sample configs are available for exactly this sort of use.
some even come with a graphical simulation of the machine.
Start LinuxCNC and expand the "sim" hierarchy. The ones with a graphical machine simulation are in sim/axis/vismach
23 Jan 2020 12:48 #155540 by mooser
Replied by mooser on topic LinuxCNC Cheating
Old thread but I'm wondering if there is a way of turning my "working" setup into a SIM to play around with when I'm not on the actual machine in the garage?
I know if I try to launch the "real" setup it'll error since the 7i76 isn't responding
I've got to try to get the gear change stuff setup (and get Andy to explain exactly what "compile and install with halcompile" means :)
Anyway, not sure that it matters but if I make any changes and get things sorted out I thought it might be simpler if I could just move HAL/INI etc files to the "real" one rather than trying to duplicate little changes between the two
M
23 Jan 2020 12:59 #155542 by cmorley
Replied by cmorley on topic LinuxCNC Cheating
Short answer - no, not with external boards (mesa) equipment.
Chris
23 Jan 2020 17:09 #155562 by Mike_Eitel
Replied by Mike_Eitel on topic LinuxCNC Cheating
I was always wondering the same question, to busy to try. ..
1. Step use list all mesa signals into one file.
2. Copy into comp and add in/ouput plus var-type
3. Compile
4. Give it the name of the meda card
5. Load instead of real hw this comp file
Unsecure if this is impossible cause of _ sign in naming convention
Mike
Time to create page: 0.152 seconds
