Problems loading LCNC after changing wheezy repositories
- aaron
11 May 2019 09:03 #133439
by aaron
Problems loading LCNC after changing wheezy repositories was created by aaron
Hi All
I just tried to change the repository for my old debian wheezy system and now LinuxCNC will not work. I have attached the error message.
I understand that debian wheezy is no longer supported officially is this right?
I need to know what repositories I should use.
the ones I have now
are:
deb archive.debian.org/debian wheezy main
deb-src archive.debian.org/debian wheezy main
deb linuxcnc.org/ wheezy base 2.7-uspace
deb-src linuxcnc.org/ wheezy base 2.7-uspace
the ones I have now
Attachment not found
- aaron
11 May 2019 09:10 #133441
by aaron
Replied by aaron on topic Problems loading LCNC after changing wheezy repositories
Sorry. I don't seem to be able to attach the error message. Here are the first sections, can they help diagnose problem?
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/aaron/linuxcnc/configs/foam_xxyz'
Machine configuration file is 'foam_xxyz.ini'
INIFILE=/home/aaron/linuxcnc/configs/foam_xxyz/foam_xxyz.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./foam_xxyz.hal
Killing task linuxcncsvr, PID=3889
Debug file information:
Note: Using POSIX non-realtime
Unknown parameter `coordinates=XYZX'
./foam_xxyz.hal:4: waitpid failed /usr/bin/rtapi_app trivkins
./foam_xxyz.hal:4: /usr/bin/rtapi_app exited without becoming ready
./foam_xxyz.hal:4: insmod for trivkins failed, returned -1
3889
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Thanks again
Aaron
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=
DISPLAY=axis
3889
Thanks again
Aaron
- Thank you received: 4652
15 May 2019 11:58 #133831
Two things.
1) You seem to not be running under a realtime kernel
What does "uname -a" say?
2) You seem to be using a 2.8 configuration with LinuxCNC 2.7.
Where did the config file come from?
Replied by andypugh on topic Problems loading LCNC after changing wheezy repositories
Unknown parameter `coordinates=XYZX'n
Two things.
- InMyDarkestHour
- Visitor
15 May 2019 18:12 - 16 May 2019 08:18 #133870
by InMyDarkestHour
Replied by InMyDarkestHour on topic Problems loading LCNC after changing wheezy repositories
meh
Last edit: 16 May 2019 08:18 by InMyDarkestHour.
15 May 2019 18:33 #133878
I don't think it is exactly the same question.
I think what has happened here is a (correct) change to the Wheezy archive, but a mistaken change from the LinuxCNC buildbot 2.8 version of LinuxCNC to the released 2.7 LinuxCNC repository.
- InMyDarkestHour
- Visitor
15 May 2019 19:49 - 16 May 2019 08:18 #133891
by InMyDarkestHour
meh
Time to create page: 0.101 seconds
