LinuxCNC Crashed - What is the name of the error file?
- fc60
- Thank you received: 9
12 May 2019 17:03 #133581
by fc60
LinuxCNC Crashed - What is the name of the error file? was created by fc60
Greetings,
My LinuxCNC crashed. (2.5.5)
On the screen was a window saying LinuxCNC had failed.
However, the computer was locked up and I could not do anything except try to reboot.
Currently, it is not booting.
If I do, by chance, boot the machine, what is the name of the file that show what failed?
I suspect it is located in the var/log/ folder?
Cheers,
David
Cheers,
David
- Online
- Thank you received: 5321
12 May 2019 17:12 - 12 May 2019 17:12 #133584
Replied by PCW on topic LinuxCNC Crashed - What is the name of the error file?
You might find some evidence of what went wrong on /var/log/syslog or one of its backups,
assuming what failed was not the harddrive.
If the PC suffered from some kind of hardware failure that was not the harddisk
you should be able to boot the drive on another (old) PC and look at the files
Last edit: 12 May 2019 17:12 by PCW.
- InMyDarkestHour
- Visitor
13 May 2019 00:28 #133607
by InMyDarkestHour
Replied by InMyDarkestHour on topic LinuxCNC Crashed - What is the name of the error file?
When you say not booting, what stage does it get to ?
Does it POST ?
Do you get a grub screen ?
Can you make a selection from grub ?
Have you tried booting from USB or CD\DVD ?
Does it POST ?
- fc60
13 May 2019 00:43 #133608
by fc60
Replied by fc60 on topic LinuxCNC Crashed - What is the name of the error file?
Greetings InMyDarkestHour,
The Motherboard is inside of the electrical cabinet that also contains the power supply and Breakout board along with the Gecko axis driver boards.
Only Ubuntu linux with LinuxCNC is on the hard disk.
I get a POST
No Grub, as there is only Linux installed.
Unable to boot from USB. Motherboard does not support it.
To boot from a CD, I have to remove the motherboard from the electrical cabinet and connect a DVD reader to it on the kitchen table.
Cheers,
Dave
I get a POST
Cheers,
Dave
- InMyDarkestHour
- Visitor
13 May 2019 01:01 #133609
by InMyDarkestHour
What boot manager are you using to boot Linux ?
- fc60
13 May 2019 01:09 #133610
by fc60
I have no clue as to what boot manager.
Linux is all there is on the hard drive.
By the way, the machine has been running fine for several years. This is a new problem.
Cheers,
David
Cheers,
David
Time to create page: 0.189 seconds
