Machine not working
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
14 May 2019 04:44 #133687 by phoenix
Machine not working was created by phoenix
I am trying to run cnc plasma using Linux cnc i updated it also upgraded but whenever i try machine is not working but it shows signlas coming out of parport
Also do i need to set parport ADRESS other than 0 when i m using onboard parport.
14 May 2019 06:03 #133693 by pl7i92
Replied by pl7i92 on topic Machine not working
hi
the parport adress is 0x378
You may not have connected enable to your drivers
Can you give us more infos about Drivers M542 ... Servo Hybrid Stepper
and the Breakout board
like this install here
  • phoenix
  • Premium Member
  • Premium Member
14 May 2019 06:30 #133695 by phoenix
Replied by phoenix on topic Machine not working
I'm using nema 23 stepper with ysspd 32-2 silent microstep driver
I checked output signals at parellal port using hal its shows everything is all right but machine not moving
14 May 2019 06:48 #133701 by pl7i92
please check the parport adress first
open Terminal (( tell us here what system are you running Please))
dmesg | grep parpo*
you shoudt see the parport like
[   18.197034] parport_pc 00:01: reported by Plug and Play ACPI
[   18.197109] parport0: PC-style at 0x378, irq 7
  • phoenix
  • Premium Member
  • Premium Member
14 May 2019 07:08 #133705 by phoenix
I have my parellal port on board and it doesn't show parellal port in lspci - vv
Also tried lspci - vv | grep parport
But no output
When i used hal parport checker and check signals on pin its shows ok but only direction signals are shown steps not shown
  • InMyDarkestHour
  • InMyDarkestHour's Avatar
  • Visitor
  • Visitor
14 May 2019 12:06 - 16 May 2019 08:21 #133732 by InMyDarkestHour
Replied by InMyDarkestHour on topic Machine not working
meh
Last edit: 16 May 2019 08:21 by InMyDarkestHour.
14 May 2019 15:36 #133766 by Mike_Eitel
Replied by Mike_Eitel on topic Machine not working
I understand that you can see signals at the your drivers.
Do you have the drive controllers enabled?
Do you have a kind og watchdog circuit?
Time to create page: 0.093 seconds
