Unable to update parport in hal
- phoenix
14 May 2019 06:32 #133696
by phoenix
Unable to update parport in hal was created by phoenix
Whenever i try to update my parport 0x378 in.
__. Hal file it shows error when starting axis
- pl7i92
- Thank you received: 358
14 May 2019 06:37 #133698
by pl7i92
Replied by pl7i92 on topic Unable to update parport in hal
hi 0x378 is out
loadrt hal_parport cfg="0x378 out"
setp parport.0.reset-time 6000
loadrt stepgen step_type=0,0,0
- pl7i92
14 May 2019 06:39 #133699
by pl7i92
please check with a terminal if it response as you like
also adress and configuration EPP ECP
dmesg | grep parpo*
[ 18.197034] parport_pc 00:01: reported by Plug and Play ACPI
[ 18.197109] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 18.292110] lp0: using parport0 (interrupt-driven).
dmesg | grep parpo*
- phoenix
14 May 2019 07:03 #133704
by phoenix
Replied by phoenix on topic Unable to update parport in hal
I tried this but whenever i change parport from 0 to 0x378 axis shows an error
Also do i need to change step type from 0, 0,0
Cause it showing only direction signals on parellal port steps not shown
- phoenix
14 May 2019 07:19 #133708
by phoenix
Do i need to make any changes on this file
- InMyDarkestHour
- Visitor
14 May 2019 12:11 #133734
by InMyDarkestHour
Replied by InMyDarkestHour on topic Unable to update parport in hal
- Thank you received: 4652
19 May 2019 20:25 #134289
The parport address is what it is, you can't change it.
So, first, find out where the parport is, then use that address.
Replied by andypugh on topic Unable to update parport in hal
- Thank you received: 2175
19 May 2019 22:22 #134294
Replied by cmorley on topic Unable to update parport in hal
What was wrong with 0 for the parport address?
linux should designate the first found parport as 0.
Also mentioning the actual error message would be helpful.
Sometimes the error is something besides what it seems.
Chris M
Chris M
The following user(s) said Thank You: phoenix
Time to create page: 0.090 seconds
