M61 expected behavior
- mydani
- Banned
- Thank you received: 9
14 May 2019 07:19 #133707
by mydani
M61 expected behavior was created by mydani
Hello all,
asking the experienced guys - what is your expectation of M61 command?
M61 shall "only" change the tool number of the current tool in spindle but not update the offsets of the current tool in spindle from the tool table? Or would you expect that M61 also sets the offsets from the table accordingly?
Regards,
Daniel
Regards,
Daniel
- BigJohnT
- Thank you received: 994
14 May 2019 10:06 #133717
by BigJohnT
Replied by BigJohnT on topic M61 expected behavior
M61 only changes the tool without the prompt for tool change if you have that installed. Otherwise it has the same behaviour as M6.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m6
G43 enables tool length compensation.
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g43
JT
JT
Time to create page: 0.116 seconds
