how to hook up parelllal port pins with gmoccapy
- phoenix
14 May 2019 11:06 #133725
by phoenix
how to hook up parelllal port pins with gmoccapy was created by phoenix
my machine is running ok on axis but now when i open gmoccapy i just cant find its configration files does anyone know where are they located
also ~~~ my pc suddenly stopped showing Usr directory in etc if anyone knows the reason most welcome to help
- InMyDarkestHour
- Visitor
14 May 2019 12:09 #133733
by InMyDarkestHour
Replied by InMyDarkestHour on topic how to hook up parelllal port pins with gmoccapy
usr in etc ? It would be weird if it was there.
you should have /usr
What distro are you using ?
- phoenix
14 May 2019 16:06 #133770
by phoenix
Replied by phoenix on topic how to hook up parelllal port pins with gmoccapy
It's Debian wheezy
- pl7i92
- Thank you received: 358
14 May 2019 16:23 #133772
by pl7i92
Replied by pl7i92 on topic how to hook up parelllal port pins with gmoccapy
why dident you just copy the folder of the mashine
and give it a DISPLAY change
make shure no pyvcp panel is in config
a basic config can at any time be changed from axis to gmoccapy
/home/yourname/linuxcnc/configs
The following user(s) said Thank You: med
- InMyDarkestHour
- Visitor
14 May 2019 16:34 #133776
by InMyDarkestHour
If /usr is missing he's got bigger problems.
- phoenix
15 May 2019 13:48 #133838
by phoenix
exactly how can i get my usr folder back i installed linux cnc again also updated it but same problem occures i cant see my etc/usr/share
- pl7i92
15 May 2019 14:56 #133844
by pl7i92
You may have Messed up with SUDO
BEST is to start over with a frech clean Harddrive or patition
and a new iso
or go to
gnipsel.com/linuxcnc/uspace/debian9-emc.html
This side provides the latest info as of uspace and 2.8 also qtvcp Gui
and a new iso
or go to
- InMyDarkestHour
- Visitor
15 May 2019 18:17 #133871
by InMyDarkestHour
there is no /etc/usr/share
there is:
/etc
/usr
/usr/share
www.dummies.com/computers/operating-syst...-file-system-basics/
Or for more info
www.google.com/search?q=linus+filesystem+basic
This is not the correct forum to use to learn about Linux in general terms, this forum is particular to the software Linuxcnc not Linux as an OS.
there is:
/etc
/usr
/usr/share
Or for more info
Time to create page: 0.101 seconds
