InMyDarkestHour wrote: If you want to see how uncaring and unable to appreciate effort check out all the trolling on Rod's Spaceship build......I'm pretty sure he cries himself to sleep every night from all the trolling.
(I figure you'd get the sarcasm Rod)
I had trouble reading that at my age so made it a bit bigger.
It take a bit to get me upset. A few years earlier on a failed attempt, I had troubles with a parallel port config which I eventually dismantled , I was just gobsmacked by the help people here willingly gave me to get my parallel port working. But I never did master it becasue I'd connected it to the motherboard wrong. In all honesty, the help I've received on this forum has been amazing. The hand holding and advice from the very first post was something I'd never experienced before on any forum. But you have to ask the right questions and I've found its always best to give it a go first.Clearly you did that.
We are still here waiting to help but we need to see some of your config rather than a simple "My VFD does not work". You have not even told us which part is broken. Is it a modbus control or are you using a potentiometer? Sadly we can't make house calls.
