Robot Arm not move in World mode
15 May 2019 07:00 #133823 by M.O.
Robot Arm not move in World mode was created by M.O.
Hello
i built a robot arm with three axes. See Picture.
I control it with the Mesacards 6i25+7i76. I tried the vismach config with genserkins. All three axes alone drive very well but if i try the world mode nothing happens. I homed the axes but nothing happens.
If i try the command "dmesg" in a terminal the following error is be shown. What this means?
I Need help because i tried so much but nothing help
I send also my INI and my HAL
15 May 2019 11:13 - 15 May 2019 11:19 #133826 by pl7i92
Replied by pl7i92 on topic Robot Arm not move in World mode
this is ABC not XYZ
use the puma560 and it will work in world mode
THE error complaqins on Joints
the HAL includes AXIS there is a MISSMTch on Version of Kins
Please tell us what verison and operation system you using Wheezy Ubuntu debian
2.7.x or 2.8.x
this Combination of files is not working
Last edit: 15 May 2019 11:19 by pl7i92.
15 May 2019 11:28 - 15 May 2019 12:18 #133829 by M.O.
Replied by M.O. on topic Robot Arm not move in World mode
I use Debian GNU/Linux 7.11(wheezy)
Linux CNC Version 2.7.11
I use the Puma 560 but it don´t work
What du you mean with"This combination of files is not working"?
The INI and the HAL under this post is the example config of PUMA560 which i find on my PC. But i think there are mistakes in it
Last edit: 15 May 2019 12:18 by M.O..
16 May 2019 13:27 #133968 by M.O.
i tried it now with JOINTS but if i want open the GUI it shows the Error: Joint.0.motor-pos-cmd not exist. But i don´t understand why.
is there a mistake in my INI or my HAl?
16 May 2019 13:58 #133972 by PCW
Replied by PCW on topic Robot Arm not move in World mode
1. You would need LinuxCNC 2.8 to have joint.0.motor-pos-cmd
2. If that "Error: Joint.0.motor-pos-cmd" is the actual error, you have Joint capitalized
which would not work
16 May 2019 14:06 #133974 by M.O.
Is there a possibility to Control the Robot arm with Linux cnc 2.7.14.?
16 May 2019 14:22 #133978 by PCW
Yes, but note that many of motions signal names have changed between 2.7 and 2.8
and joint.0.motor-pos-cmd is a LinuxCNC 2.8 pin name.
I do suspect that LinuxCNC 2.8 would be a better choice for robotics since it makes a clear distinction between joints and axis
21 May 2019 08:02 #134453 by M.O.
I read a lot about Linux cnc 2.8 and it is not a official Edition of Linux cnc.
I would like to try it with 2.7.14 but i have still no idea why my world mode not run.
Any ideas please?
21 May 2019 13:42 #134477 by Todd Zuercher
Replied by Todd Zuercher on topic Robot Arm not move in World mode
Even though 2.8 is still under development, it is still a very usable program. I think it may be very close to being released. I would be surprised if it is not released before the end of the year. (However I am not one of the developers,)
22 May 2019 13:57 #134579 by M.O.
i have updated to 2.8
after Homing my Axes it shows an error "KinematicsInverse failed".
I think my D-H Parameters are wrong or?
Time to create page: 0.267 seconds
