Installing softwares
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
15 May 2019 15:29 #133849 by phoenix
Installing softwares was created by phoenix
can anyone help me with how to install softwares in linux cnc
like i want to install gedit or any other software how to do it
it says unable to locate pakage
do i need to add repository for every pakage
any repository s ???/
15 May 2019 16:40 #133854 by pl7i92
Replied by pl7i92 on topic Installing softwares
Depending on what os you use
TERMINAL
sudo apt-get install gedit
sudo apt-get install freecad
sudo apt-get install librecad
IT is realy hard to give you infos as you always do not say what you install
what version y<ouare on
how your mashine looks
i guess it is a puma like robot
you try to get it in to catrtesian XYZ
while it needs to be configurerd in Angular mode
THE pinnames have changed from 2.8 so noone can help you as you do not tell us the system
  • phoenix
  • Premium Member
  • Premium Member
15 May 2019 17:08 #133861 by phoenix
Replied by phoenix on topic Installing softwares
im using debian wheezy
15 May 2019 18:01 - 15 May 2019 18:01 #133867 by Todd Zuercher
Replied by Todd Zuercher on topic Installing softwares
If you installed using the Linuxcnc Wheezy ISO (Debian 7), the Debian repositories have changed since Wheezy is now EOL. They have been moved to archive.debian.org/debian/
You will need to change your repository source list for all of the Debian archives to the new "archive" address. You can do this via Synaptic or by editing /etc/apt/sources.list directly.
Last edit: 15 May 2019 18:01 by Todd Zuercher.
  • InMyDarkestHour
  • InMyDarkestHour's Avatar
  • Visitor
  • Visitor
15 May 2019 18:08 - 16 May 2019 08:18 #133868 by InMyDarkestHour
Replied by InMyDarkestHour on topic Installing softwares
meh
Last edit: 16 May 2019 08:18 by InMyDarkestHour.
Time to create page: 0.234 seconds
