7i92M-7i77 config
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 May 2019 14:14 #134812 by bevins
7i92M-7i77 config was created by bevins
Does PNCConf have 7i92 / 7i77 config? I dont remember seeing ethernet boards.
IF not, would anyone like to share a basic 7i92 - 7i77 config? XYYZ
Jumping in the mesa ethernet world. I've always used 5i25's.....
Thanks, I'll check the sim if there are any..
Bob
24 May 2019 14:40 #134814 by PCW
Replied by PCW on topic 7i92M-7i77 config
I know pncconf in LinuxCNC master supports the 7I92, not sure about the version with 2.7.14
If its not supported, its not a big deal to change a 5I25 config to a 7I92 config,
basically you do a global replace of "5i25" with "7i92" in the hal file,
replace hm2_pci with hm2_eth, and add the IP address to the loardrt hm2_eth line
The following user(s) said Thank You: bevins
  • Moderator
  • Moderator
25 May 2019 00:10 #134862 by tommylight
Replied by tommylight on topic 7i92M-7i77 config
Use the force, Luke........hmmmm use the "search and replace" feature in all text editors in Linux, or Ctrl+h.
Makes life much easier.
25 May 2019 08:56 - 25 May 2019 08:57 #134879 by pl7i92
Replied by pl7i92 on topic 7i92M-7i77 config
like for the eeprom adress jumperd
loadrt hm2_eth board_ip=192.168.1.121 config="num_stepgens=4, num_encoders=0, num_pwmgens=1"
setp hm2_7i92.0.pwmgen.pwm_frequency 100000
setp hm2_7i92.0.pwmgen.pdm_frequency 6000000
setp hm2_7i92.0.watchdog.timeout_ns 10000000
Last edit: 25 May 2019 08:57 by pl7i92.
Time to create page: 0.298 seconds
