Using glades vcp panel with axis
26 May 2019 02:48 #134947 by Kriti
Using glades vcp panel with axis was created by Kriti
hiii friends .. I'm kriti
Its been a week i started using linux cnc
I'm totally noob to programming
I want to use glades vcp panel with axis
And also i m unable to make connections
Can u guys help me????
[also share if u have any plasma gui] :P :P
26 May 2019 05:24 #134965 by cmorley
Replied by cmorley on topic Using glades vcp panel with axis
Greetings!
here are the docs:
linuxcnc.org/docs/2.7/html/gui/gladevcp....into_axis_like_pyvcp
There is a group working on plasma equipment, including GUI modifications - just search the forum.
Also when you are having a problem and need help with configuration, please post your config files so others can look at it.
Welcome to the linuxcnc forum 1
Chris M
26 May 2019 06:40 #134980 by pl7i92
Replied by pl7i92 on topic Using glades vcp panel with axis
Hi
you may start with Axis till plasma runs as expected with no extras
then just change the GUI and go on
WHAT Hardware are you using
is the plasma already build or in construction
What Operation System did you install Wheezy or Stretch
26 May 2019 09:27 #134989 by Kriti
Replied by Kriti on topic Using glades vcp panel with axis
Sir my machine is up and running on axis default interface
Without torch
I'm using debian wheezy
