Unexpected arc move at turning operation.
- vmihalca
- Thank you received: 22
28 May 2019 19:36 #135189
by vmihalca
Unexpected arc move at turning operation. was created by vmihalca
Hi guys,
I have made a part in fusion 360, done the cam then imported the code.
In preview all looks fine, but when executing the moves, instead of making a sharp corner, I end up with an arc.
- Thank you received: 1472
28 May 2019 22:47 #135215
Replied by Todd Zuercher on topic Unexpected arc move at turning operation.
That is normal expected behavior for G64 with no P tolerance. That is the default setting. You need to specify G64 Pn where n equals the max path deviation.
