I can't install gedit. Can somone help?
- tml
30 May 2019 22:05 #135429
by tml
I can't install gedit. Can somone help? was created by tml
So I've looked every where and still can't find the gedit software in my computer. I believe my operating system is Debian GNU/Linux 7.11 (wheezy).
I went into Synaptic Package Manager and found gedit (ver 3.4.2-1) and gedit-common (ver 3.4.2-1) and tried to install those. Then my computer gave me this error:
W: Failed to fetch http.debian.net/debian/pool/main/c/cogl/...l9_1.10.2-7_i386.deb
404 Not Found [IP: 2a04:4e42:3f::204 80]
I've also tried running the command:
sudo apt-get update
sudo apt-get install gedit
It also comes up with error:
Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Can someone point me what to do to solve this issue?
sudo apt-get update
- BigJohnT
- Thank you received: 994
30 May 2019 22:39 #135434
by BigJohnT
Replied by BigJohnT on topic I can't install gedit. Can somone help?
You need to update your synaptic package manager sources, wheezy is at EOL.
forum.linuxcnc.org/29-forum-announcement...-repositories#135195
JT
JT
The following user(s) said Thank You: tml
- tml
31 May 2019 03:02 #135444
by tml
Replied by tml on topic I can't install gedit. Can somone help?
- pl7i92
- Thank you received: 358
31 May 2019 06:53 #135449
by pl7i92
Replied by pl7i92 on topic I can't install gedit. Can somone help?
if you put the File /etc/apt/source.list here
we can get it right for you
or go here to see more help
forum.linuxcnc.org/29-forum-announcement...-wheezy-repositories
- tml
31 May 2019 16:26 - 31 May 2019 16:27 #135482
by tml
Last edit: 31 May 2019 16:27 by tml.
- BigJohnT
31 May 2019 23:25 - 31 May 2019 23:35 #135505
by BigJohnT
That looks correct but the error is a malformed line in /etc/apt/source.list so you need to edit it to correct the bad line.
How did you add the archive sources?
I don't see the main contrib non-free in any of your archive sources and it must be there.
Andy, posted the contents of the /etc/apt/sources file so compare your sources file to his.
forum.linuxcnc.org/29-forum-announcement...-repositories#135506
JT
JT
Last edit: 31 May 2019 23:35 by BigJohnT.
- Thank you received: 4652
01 Jun 2019 00:12 #135515
I would suggest installing Geany instead of Gedit. Gedit is the Gnome editor, and if you install it you end up installing aboug a gigabyute of Gnome desktop to go with it.
If you install Geany you just get a text editor.
Replied by andypugh on topic I can't install gedit. Can somone help?
- tml
01 Jun 2019 15:04 #135570
by tml
It looks like I was not supposed to add the additional archive sources. But rather just edit the base and security URIs per the instruction.
So I went back, removed the archive sources that I manually added. Then edited the existing base and security URIs.
I edited the URI and Distribution blocks. Now they look the same as the screenshot shown in Andy's post.
Here's mine after the edit:
Then I run the command sudo apt-get update -o Acquire::Check-Valid-Until=false
I get some "Failed to fetch ... " errors and I don't know if that is normal or not. Here's a screenshot of that:
I am now able to install gedit though:
- BigJohnT
01 Jun 2019 15:27 #135572
by BigJohnT
I do think the / after deb-src archive.debian.org/debian-security/ wheezy/updates main contrib non-free is not correct. I'll see if I have a Wheezy HD laying around and test that.
I also second Geany as an editor, I don't think gedit brings a gigabyte of Gnome along with it maybe only 1/2Gb.
JT
JT
- BigJohnT
01 Jun 2019 15:28 #135573
by BigJohnT
JT
JT
Time to create page: 0.556 seconds
