Preventing LinuxCNC from changing iptables?
- JetForMe
- Thank you received: 27
02 Jun 2019 07:24 #135616
by JetForMe
Preventing LinuxCNC from changing iptables? was created by JetForMe
I notice that while linuxcnc is running, it configures iptables to severely limit network access. I tend to ssh to my linuxcnc machine from my Mac because it makes it a lot easier to tinker (I'm just much more comfortable in macOS). I'm able to run many of the GUI apps over X11/ssh, but as soon as I launch linuxcnc, it kill my network connections.
I'm not worried about the potential issues with that right now (CPU load, etc.). I'm just trying to get my machine to limping.
I've thus far been able to find a solution to this, searching for things like "linuxcnc iptables" or "linuxcnc prevent iptables changes".
- JetForMe
02 Jun 2019 07:45 #135617
by JetForMe
Replied by JetForMe on topic Preventing LinuxCNC from changing iptables?
Ah, nevermind. I configured my system to talk to the Mesa card over the other Ethernet port, and now it seems to leave network access intact. Sorry for the noise, hope this helps someone else.
- Thank you received: 5334
02 Jun 2019 12:49 #135628
Replied by PCW on topic Preventing LinuxCNC from changing iptables?
This is a deliberate part of the hm2_eth driver so that there is no spurious network
activity on the host interface used for real time. Its a relatively recent addition, you used
to be able to have the real time link share regular network traffic, this is obviously not
ideal but does work at low servo thread rates.
- JetForMe
02 Jun 2019 13:00 #135630
by JetForMe
It's all good now that I'm using a separate interface to talk to the 7i76e. Otherwise I wouldn't be able to use a network file share to get NC files onto the machine, and that would've sucked!
- Thank you received: 7490
03 Jun 2019 00:10 #135678
Replied by tommylight on topic Preventing LinuxCNC from changing iptables?
From your posts I can gather that you have your mesa board wired through a switch or a hub ( hubs are almost extinct ), and that is not advisable ever. Direct cable from computer to the board, always.
Now that you have two network cards, most probably you have it wired directly, right?
- JetForMe
03 Jun 2019 01:17 #135681
by JetForMe
Oh yes, it's wired directly. Previously it was just on the main network (via switch) because I was just getting things to talking to each other, and I didn't want to add complexity. But I finally got to point where I decided to try making it work with the dedicated port, and now they're wired to each other with a single Ethernet cable.
03 Jun 2019 07:08 #135704
Replied by andypugh on topic Preventing LinuxCNC from changing iptables?
Ethernet to Mesa + USB Wifi dongle is simple and works well.
(I am also a Mac user, in fact I do most of my LinuxCNC dev work actually sat at my Mac and SSH-ing into various headless Linux boxes and using a collection of VMs.)
Time to create page: 0.135 seconds
