3 axis surface grinder linuxcnc
- aventtini
- Visitor
02 Jun 2019 11:15 #135625
by aventtini
3 axis surface grinder linuxcnc was created by aventtini
Hi guys , next project a Elb surface grinder . I want to retrofit the machine because this osai control is conplicated to use. My plan is x axis Larkin step to linear , y axis same , z axis stepper with realtime processing bord ( this bord we think it dont work on servo and for this we want to you a gap conpensation board ) . Then we want to use a 7i76 because the compensation bord has only puls/dir. The axis on z is trapezioidal 1mm . My problem is that i need to axis is auto , like a macro and z axis working in manual from handwheel. Olso i need to develop a custom macro interface to make the program from mdi. But in mdi z handwheel dont work. I have attach a video of a favretto grinder that works like i want
- bevins
- Thank you received: 338
02 Jun 2019 14:57 #135636
by bevins
Replied by bevins on topic 3 axis surface grinder linuxcnc
What servo motors and drives are on that machine?
Show picture or video of the cabinet showing the drives.
I would guess AC servos. This should be no problem to convert to Linuxcnc.
- aventtini
- Visitor
02 Jun 2019 16:31 #135642
by aventtini
Replied by aventtini on topic 3 axis surface grinder linuxcnc
They are ac servo with velocity command +-10v . My problem is the logic of the NC . The xy axis your in auto but z axis works in manual . That mens when i start a program my z axis still move from handwheel. I have done 12-14 machines only in milling with mesa this is diffrent configuration
- Thank you received: 4652
03 Jun 2019 06:44 #135701
Replied by andypugh on topic 3 axis surface grinder linuxcnc
If you use the 2.8 branch then it is trivial to hook up a handwheel as an external offset to the Z axis. Then both LinuxCNC and the handwheel can move the axis. (which means that you can trivially add a retract and return button, for example)
The following user(s) said Thank You: aventtini
- aventtini
- Visitor
03 Jun 2019 07:06 #135703
by aventtini
I will need to do some reading. The external offset must have some hal pins somehow.
03 Jun 2019 07:09 #135705
