ABOUT THC
- AgentWD40
- Thank you received: 96
By the way:
Hypertherm grounding pdf: xnet.hypertherm.com/Xnet/library/download/?file=HYP103900
Torchmate:
torchmate.com/uploads/downloads/Technica...nding_TM_Control.pdf
torchmate.com/uploads/support/pdfs/Machi...ng%20Information.pdf
- Clive S
- Thank you received: 486
The arc voltages are not very healthy (and probably lethal). If you have the 300 inside the case everything is contained and just a 5 volt power in and a 5 volt frequency out is all that is required.
But if you bring the wires outside it is a good idea to use a THCAD-10 and add the scaling resistors on the inside of the case so the voltage is no longer lethal in the outside world.
The other thing going for the THCAD-10 is that you can control the full scale reading so you might find with your machine you can get away with a 150 volt or 200 volt range so you have greater resolution in the decoded torch voltage.
Rod Thanks: I am happy with the grounding , EMI and high voltage issues . If the THC won't fit into the case I will mount a metal box on it with the THC inside.
I am not sure where to exactly connect the input of the THC to ie is it straight from the output of the plasma -ve and +ve terminals via say 100k resistors in each leg? Also do I use the 300 or 0 thc
Photos:- photos.app.goo.gl/u3LRnzeJQTSEFMjV8
- billykid
- Thank you received: 82
I have only the doubt of the external resistance, I have some problem with the language and I have not understood correctly if it goes one on the negative.
now I have a divider that would also give the right tension but to what I read they say they do different.
if you can make a sketch of the scheme I understand that without any problem. pneumatic torch without hf is my plasma.
- Clive S
- Thank you received: 4141
Follow the instructions on Page 6 "Extending the input range" of the THCAD Manual . Split the calculated resistance in two and insert that value on each electrode signal.
Clive. That looks identical to one we tried to repair. One of the mosfets in that row self diagnosed a problem with some smoke signals. After we tried it again, the Whole machine went of with a Huge bang and issued a cloud of smoke so it was consigned to the tip! Sorry but I threw the torch out. It is a High Frequency Pilot Arc Start I think. Eg. It will fire in the air. Lots of EMI.
- Clive S
I know its not a good machine but it was free. The on/off switch was faulty but I had a new one and now it powers up but I can not test it until the new torch arrives from China. I have started to build the machine 1250x700 cut size with gantry across the 1250 using twin nema 34 with a on racks. So gantry squaring needed .
What I gather is I will need a THC10 + 7i96 that I have used in the past.
- Thank you received: 7465
With Nema 34 you will get a lot of vibrations and that would show in the cuts.
Nema 23 at any length would be perfect but need 1/16 micro stepping to run smooth with that weight.
Side info, there are at least 3 lengths for any Nema size of motors, never studied it, but some refer to it as double and triple length, some just give the current with no mention of length.
Currently I think I have single and double Nema 17, all 3 lengths of Nema 23 and 34, so I can take some pictures if anyone is interested.
Motor inertia is different for the similar holding torque of the motors.
