how to add axix
7 years 4 months ago #135908
by Nkonnect
how to add axix was created by Nkonnect
hi every one
I have installed Debian in computer and i have MESA 7I76E card
store.mesanet.com/index.php?route=produc...oduct&product_id=290
I am new in LinuxCNC.
Basic Installation and setup was done.
3 axis are working.
Now i dont understand how to add axis.
I need 5 axis.
Would any one help me to run 5 axis ??
Thank You
nngohel
3 axis are working.
I need 5 axis.
Thank You
nngohel
7 years 4 months ago #135911
by pl7i92
Replied by pl7i92 on topic how to add axix
hi
i got a 5Axis working on a 7i92
What Mashine Type do you got MILL 5Axis or a Gantry type table plasma
Whar Operation system are you on
is it 2.8 Master
is it a Compile or only install
Many infos needed
AXIS Geometry ACXYZ
CAXYZ
BA AB ....
this is needed for te HAl and ini to work
is it 2.8 Master
Many infos needed
AXIS Geometry ACXYZ
CAXYZ
BA AB ....
7 years 4 months ago #135980
Replied by tommylight on topic how to add axix
Basically you need to add two more axis to the INI and half file, so you can copy and paste one of the existing axis and change the steppgen number and joint number, also if they are rotary change that from the usual linear joint/ axis. All in all about 10 minutes of editing in a text editor. FYI avoid using windows for editing text files, use the included text editor in Linux.
The following user(s) said Thank You: Nkonnect
7 years 4 months ago #136014
by Nkonnect
Thank For Reply.
now 5 axis are working.
But not calibrate.
Today I will calibrate and then I will post what happen...
In my machine 3 rotary axis and 2 Linear Axis.
4 servo motor and 1 stepper motor.
Any suggestion for rotary axis calibration ??
Replied by Nkonnect on topic how to add axis
Thank For Reply.
But not calibrate.
7 years 4 months ago #136031
by pl7i92
i did mount a 30mm Bar to the outward rotary hole and did a 10deg
for me as it is 1.5x Wormrotation
with a Dial back and forth to mesure any offset
if it is clar set ther at 10deg zero and move on
G91 G1 A 10 F500
and so on till it workes around
if you can go with postprocessor use 360 deg only AB NOT for C axis
i use there -45 to 400deg
for interfearing worm behavier
G91 G1 A 10 F500
7 years 4 months ago #136122
If using Axis GUI in the machine menu there is calibration that will open a small window you can use to change and test settings without the need to restart Linuxcnc. It is simple math, set it at some value, use MDI to move a certain distance, check if it moved more or less than it should, adjust the scale accordingly .
Time to create page: 0.109 seconds
