PROBLEM WITH Z AXIS REZEROING BEFORE PROGRAM START
17 Jun 2019 14:26 #137127 by andypugh
So when I try to edit my INI file it seems to not have any effect on the machine.
It isn't 100% clear what you are doing, but the INI file values are only read once, when you start up LinuxCNC.
You need to restart LinuxCNC (not the PC, just LinuxCNC) to see the effect of INI file changes.
17 Jun 2019 18:15 #137140 by newbynobi
Are you shure, that you do edit the correct INI File?
I found many times, that users have such a mess in their cionfig folder, that they did edit the wrong file.
Norbert
Time to create page: 0.210 seconds
