Error code on exit
- Vector459
21 Jun 2019 14:39 #137494
by Vector459
Replied by Vector459 on topic Error code on exit
Okay I tried the settings in the bios like you suggested and it did not work same result same error.
- Vector459
21 Jun 2019 14:41 #137495
by Vector459
I figured out what it was I did not have my gamepad USB plugged in if I plug in my gamepad controller linuxcnc starts fine. But I do not use the controller and I did not think that would make linuxcnc not start? any ideas how I correct that as I don't even use the GamePad controller and I don't want to have to have it connected for linuxcnc to work properly.
Thank you so much for taking the time to help.
- Thank you received: 4648
21 Jun 2019 15:09 #137496
That wasn't at all evident from the error messages you posted.
Is the gamepad configured by a separate HAL file? It seems likely that it is as I haven't noticed anything related to it in the files you have shown us.
if it is then you can just comment-out that HAL file in the [HAL] section of the INI file.
Replied by andypugh on topic Error code on exit
- Vector459
21 Jun 2019 15:22 #137498
by Vector459
This is a cutom_postgui config in my folders:
# Include your customized HAL commands here
# The commands in this file are run after the AXIS GUI (including PyVCP panel) starts
loadrt or2 count=2
loadrt mux4 count=1
loadrt and2 count=4
loadrt not count=2
loadrt scale count=1
loadrt abs count=1
loadrt lowpass count=1
addf or2.0 servo-thread
addf or2.1 servo-thread
addf mux4.0 servo-thread
addf and2.0 servo-thread
addf and2.1 servo-thread
addf and2.2 servo-thread
addf and2.3 servo-thread
addf not.0 servo-thread
addf not.1 servo-thread
addf scale.0 servo-thread
addf abs.0 servo-thread
addf lowpass.0 servo-thread
# set the jog speed for the joypad
# this one must be 0 to prevent motion unless a button is pressed
setp mux4.0.in0 0
setp mux4.0.in1 .25
setp mux4.0.in2 10
setp mux4.0.in3 50
# the following does the magic of setting the jog speeds
net remote-speed-slow or2.0.in0 input.0.btn-x
net remote-speed-medium or2.1.in0 input.0.btn-a
net remote-speed-fast or2.0.in1 or2.1.in1 input.0.btn-b
net joy-speed-1 mux4.0.sel0 <= or2.0.out
net joy-speed-2 mux4.0.sel1 <= or2.1.out
net joy-speed-final halui.jog-speed <= mux4.0.out
net joy-x-jog halui.jog.0.analog <= input.0.abs-y-position
net joy-z-jog halui.jog.2.analog <= input.0.abs-rx-position
#sets button5 to toggle machine on & off
net machine-is-on halui.machine.is-on => and2.0.in0
net machine-is-on halui.machine.is-on => not.0.in
net not-machine-is-on not.0.out => and2.1.in0
net button5 input.0.btn-tr => and2.0.in1
net button5 input.0.btn-tr => and2.1.in1
net machineOff and2.0.out => halui.machine.off
net machineOn and2.1.out => halui.machine.on
#sets button7 to toggle estop on & off
net estop-is-on halui.estop.is-activated => and2.2.in0
net estop-is-on halui.estop.is-activated => not.1.in
net not-estop-is-on not.1.out => and2.3.in0
net button7 input.0.btn-tl => and2.2.in1
net button7 input.0.btn-tl => and2.3.in1
net estopOff and2.2.out => halui.estop.reset
net estopOn and2.3.out => halui.estop.activate
setp lowpass.0.gain .001
# Display spindle speed in pyvcp bar
setp scale.0.gain 60 #convert velocity per sec into rpm
net spindle-velocity => lowpass.0.in
net filtered-spindle-velocity <= lowpass.0.out => abs.0.in
net absolute-spindle-velocity <= abs.0.out => scale.0.in
net scaled-spindle-velocity <= scale.0.out => pyvcp.spindle-speed
# Connect unhome pins in hal to pyvcp buttons
net unhome-x halui.joint.0.unhome <= pyvcp.x-unhome
net unhome-z halui.joint.2.unhome <= pyvcp.z-unhome
# Connect rapid home pins to pyvcp buttons
net remote-rapid-home halui.mdi-command-00 <= pyvcp.rapid-to-home
loadrt or2 count=2
loadrt mux4 count=1
loadrt and2 count=4
loadrt not count=2
loadrt abs count=1
setp mux4.0.in0 0
setp mux4.0.in1 .25
setp mux4.0.in2 10
setp mux4.0.in3 50
- Vector459
21 Jun 2019 15:24 #137499
by Vector459
# Generated by stepconf at Sun Dec 15 13:01:19 2013
# overwritten when you run stepconf again
[EMC]
MACHINE = my-lathe
DEBUG = 0
[DISPLAY]
TKPKG = Ngcgui 1.0
TKPKG = Ngcguittt 1.0
# Ngcgui must precede Ngcguittt
NGCGUI_FONT = Helvetica -12 normal
# specify filenames only, files must be in [RS274NGC]SUBROUTINE_PATH
NGCGUI_PREAMBLE = in_std.ngc
NGCGUI_SUBFILE = odtaper.ngc
NGCGUI_SUBFILE = taper-od.ngc
NGCGUI_SUBFILE = radius.ngc
NGCGUI_SUBFILE = od.ngc
NGCGUI_SUBFILE = idtaper.ngc
NGCGUI_SUBFILE = taperid.ngc
NGCGUI_SUBFILE = odtip.ngc
NGCGUI_SUBFILE = g76.ngc
NGCGUI_SUBFILE = drill.ngc
NGCGUI_SUBFILE = face.ngc
# specify "" for a custom tab page
NGCGUI_SUBFILE = ""
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_GRAPHIC = ""
INTRO_TIME = .01
PROGRAM_PREFIX = /home/probotix/linuxcnc/nc_files/ngcgui_lib/
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
PYVCP = custompanel.xml
LATHE = 1
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = /home/probotix/linuxcnc/nc_files/ngcgui_lib/
RS274NGC_STARTUP_CODE = G18 G20 G90
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = my-lathe.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
MDI_COMMAND = G0 X0 Z0
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.17
MAX_LINEAR_VELOCITY = 1.70
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
BACKLASH = 0.007
MAX_VELOCITY = 0.4
MAX_ACCELERATION = 30.0
STEPGEN_MAXACCEL = 37.5
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -2.3264
MAX_LIMIT = 2.3264
HOME_OFFSET = 0.0
#HOME_SEARCH_VEL = 0.050000
#HOME_LATCH_VEL = 0.050000
#HOME_SEQUENCE = 1
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.7
MAX_ACCELERATION = 90.0
STEPGEN_MAXACCEL = 112.5
SCALE = 2000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -8.4
MAX_LIMIT = 0.0001
HOME_OFFSET = 0.0
#HOME_SEQUENCE = 0
[EMC]
MACHINE = my-lathe
DEBUG = 0
[DISPLAY]
TKPKG = Ngcgui 1.0
NGCGUI_SUBFILE = ""
DISPLAY = axis
EDITOR = gedit
INTRO_GRAPHIC = ""
INTRO_TIME = .01
LATHE = 1
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
HALUI = halui
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
BACKLASH = 0.007
MAX_VELOCITY = 0.4
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -2.3264
MAX_LIMIT = 2.3264
HOME_OFFSET = 0.0
#HOME_SEQUENCE = 1
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 1.7
SCALE = 2000.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -8.4
MAX_LIMIT = 0.0001
HOME_OFFSET = 0.0
#HOME_SEQUENCE = 0
21 Jun 2019 15:32 #137500
I think there must be something else somewhere too, with a "loadusr hal_input......" line.
You need to deactivate that, and all lines that mention input.0 in other HAL files.
- Vector459
21 Jun 2019 15:53 #137501
by Vector459
Okay I'll do some digging. And thank you again for your patience I'm a New Lenox CNC user coming from mach3 so I'm trying to learn but it's very different so again you're helps appreciated.
Time to create page: 0.121 seconds
