Compiling Preempt RT failed
- bevins
- Thank you received: 338
07 Jun 2019 21:45 #136254
by bevins
Compiling Preempt RT failed was created by bevins
Everything went ok except for when make modules_install got an error. "cannot use CONFIG_STACK_VALIDATION=y" This shouldn't matter.
It did install, but I got error when booting. Couldnt find suitable memory target. thats weird cause it did install the kernel.
Linux Mint 19.1 following JT's Linux Mint 19.1 RT Kernel instructions
- bevins
07 Jun 2019 21:52 #136255
by bevins
Replied by bevins on topic Compiling Preempt RT failed
WOAH!! I dont know whats going on. The new image is way bigger than the original. Like more than 10 times.
anyone know a way of making it smaller? get rid of stuff I don't need during compile?
- bevins
07 Jun 2019 22:15 #136256
by bevins
/etc/initramfd-tools/initramfs.conf modules=dep should fix it.
It is default set to most which installs everything. Thats probably why it is so big.
Recompile....
Recompile....
- bevins
07 Jun 2019 22:55 #136259
by bevins
Also need to strip modules with....
make INSTALL_MOD_STRIP=1 modules_install
then make install
This should get the image down to a size grub wont complain with.
then make install
- Thank you received: 4144
08 Jun 2019 00:08 #136260
Replied by rodw on topic Compiling Preempt RT failed
Bob, if you've got as far as compiling the PREEMPT_RT, why don't you just compile Linuxcnc as well? Its not that hard.
I know its been a while, but for me the kernel just always compiled. I don't understand why you are stripping stuff out (unless HDD is too small). The only thing i remember is that sometimes the menuconfig (if thats what it was called as I've forgotten) did not like the graphical version so I used the text based version.
- bevins
08 Jun 2019 01:03 #136264
by bevins
The image is way too big and grub complains of it. It is big because it is compiling everything and installing all the modules.
What I just tried failed miserably. I dont know why it worked for JT and not me. I followed his to the letter.
I could try stretch, but I want Mint.
This is a known issue. image too big issue
Theres a couple threads on here about it. Linuxcnc on Mint 19
I tried to find a way around it. That didn't work. I knew I should have purchased the 5i25 instead of the 7i92M
- Thank you received: 7471
08 Jun 2019 01:03 #136265
Last compile ended up at 980MB!
Replied by tommylight on topic Compiling Preempt RT failed
Yup noticed that on two of the last compiles, it also makes the boot time an eternity even on an NVME or an SSD that does 580MB reads per second ! So I found a ready made RT kernel on an audio website and been using that for the last 3 months. Latency is a bit worse with it, but not by much. Am on a tablet so can not get the wersion.WOAH!! I dont know whats going on. The new image is way bigger than the original. Like more than 10 times.
- bevins
08 Jun 2019 01:12 #136267
by bevins
Anyone know if compiling the preempt RT does it on Mint 18 also?
08 Jun 2019 01:39 #136270
It did not, it was all good. I still have the kernel compiled on 18.1 that I use on 19.1 and it works perfectly, just an older version.
I did the new version as I have an Asus Prime Z270 board with an quad core i5 7400 and NVME drive so I thought it deserved a new version.
- bevins
08 Jun 2019 01:41 #136271
by bevins
oh, I have an mint 18 cd I think. I'll try that.
Time to create page: 0.099 seconds
