2.9 Master now out at builtbot
- pl7i92
- Thank you received: 358
08 Jun 2019 13:26 #136294
by pl7i92
2.9 Master now out at builtbot was created by pl7i92
Today i upgrated
and i found the 2.9.0 at the builtbot
stretch RT preampt
did work nice no problems on install
stretch RT preampt
- pl7i92
08 Jun 2019 13:32 #136295
by pl7i92
Replied by pl7i92 on topic 2.9 Master now out at builtbot
The following user(s) said Thank You: tommylight, AgentWD40
- Thank you received: 7471
08 Jun 2019 23:33 #136313
Replied by tommylight on topic 2.9 Master now out at builtbot
It's been mentioned several times here that master moved to 2.9, but in stealth mode !
- Thank you received: 1472
09 Jun 2019 11:34 #136366
Replied by Todd Zuercher on topic 2.9 Master now out at builtbot
The change isn't official yet,but was nessisary for developers to do the things they need to get done for the imminent release of 2.8. Expect the announcement in a few weeks.
- pl7i92
09 Jun 2019 14:41 #136376
by pl7i92
is there a feather close like in Freecad
only bugfix to the system
as there are regular builds to master at buildbot
what is the main stop to prevent the release of 2.8 as it is now overtopd by master
i guess it is not clear to go with the os
the gnipsel showes as it can be in many even lubuntu is to take action
- Thank you received: 4652
10 Jun 2019 17:11 #136493
Yes. Switching master to 2.9 opened that up for new experimental features (such as reverse-run, which is now in 2.9) while feature-freezing 2.8 (so now bug-fixes, doc changes and standalone components (such as HAL components and possibly new GUIs) are allowed.
Basically if there is _any_ chance that a change will break an existing config then it has to go in to 2.9 and not 2.8.
Replied by andypugh on topic 2.9 Master now out at builtbot
Time to create page: 0.164 seconds
