HAL widgets not showing in glades vcp
- phoenix
16 Jun 2019 15:23 #137048
by phoenix
HAL widgets not showing in glades vcp was created by phoenix
im using debian 9 it doesnt have glades preinstalled so i installed it manually but i cant see any hal widgets in glades vcp
also sudo apt-get install glade-gtk2 this says unable to locate pakakge
any help would be greatly appreciated
- Grotius
- Thank you received: 2349
16 Jun 2019 16:04 - 16 Jun 2019 16:09 #137049
by Grotius
Replied by Grotius on topic HAL widgets not showing in glades vcp
This sample is for a 64 bit install to get the linuxcnc glade widgets loaded. You can find the files for 32 bit install in the same way.
linuxcnc.org/dists/wheezy/base/binary-amd64/libgladeui-1-11_3.8.0-0ubuntu6_amd64.deb
linuxcnc.org/dists/wheezy/base/binary-amd64/glade-gtk2_3.8.0-0ubuntu6_amd64.deb
linuxcnc.org/dists/wheezy/base/binary-amd64/glade-gnome_3.8.0-0ubuntu6_amd64.deb
Unpack in terminal :
$ sudo dpkg -i libgladeui-1-11_3.8.0-0ubuntu6_amd64.deb
$ sudo dpkg -i glade-gtk2_3.8.0-0ubuntu6_amd64.deb
$ sudo dpkg -i glade-gnome_3.8.0-0ubuntu6_amd64.deb
Now you have also the glade program fully functional for your linuxcnc needs.
To install glade :
To install glade :
Last edit: 16 Jun 2019 16:09 by Grotius.
- udoS
- Thank you received: 25
17 Dec 2022 09:38 - 17 Dec 2022 09:39 #259721
by udoS
Replied by udoS on topic HAL widgets not showing in glades vcp
@grotius
I've been looking into your HAL-Widgets project:
One question I have: after starting the QtApp,
I have the pins and the comp in halui;
However, the comp state stays in initializing, never turning to ready;
I could not find any info's about the state of the comps;
Any info would be nice.
Best regards.
Best regards.
Last edit: 17 Dec 2022 09:39 by udoS.
