XBOX 360 Controller
- ictponder
21 Jun 2019 16:23 #137503
by ictponder
XBOX 360 Controller was created by ictponder
The analog sticks are way too sensitive and will not zero out completely. I've read the older wiki article and it addresses setting up deadzones. I was hoping I could just use the a, b, x and y buttons to control the x and y axis instead of joysticks?
Here is my joypad hal file
- pl7i92
- Thank you received: 358
22 Jun 2019 08:00 #137563
by pl7i92
Replied by pl7i92 on topic XBOX 360 Controller
hi
i use this controller type alot
and i got a simple video here
depending on version of linuxcnc and operation system the hal is different
also what you like to do
you can for example interact the THC on a plasma with it
The following user(s) said Thank You: ictponder
