Linear move on line 29 would exceed Axis X's positive limit
7 years 4 months ago #137858 by Surfermann
My cnc plasma has both rotary and sheet. I am using Command CNC to operate them. I have Command CNC set up with 2 configurations, one for sheet and one for rotary. Today I attempted to cut a new g-code for a rotary part. I got this message: Linear move on line 29 would exceed Axis X's positive limit. I then tried to cut another part with a g-code I've used previously and got the same error message.
I then switched to plate and it cut fine. I rebooted everything and tried rotary again with the same error message. The difference between sheet and rotary is the configuration. I checked the configuration for rotary and it looked un-changed with the limits set at -10,000 and 10,000.
Any thoughts. Where should I look next?
Thank you
7 years 4 months ago #137869 by pl7i92
you need to home/REF the machine at the begining of every work to get a start place
BEST for NOW is GET THE mashine manuell moed to a corner position WHERE the REF point is
goto the mashie folder
DELETE the *.var FILE
and the *.var.bak
file
then the mashine will act as you like
BUT
As you say there is a great missunderstanding in your mashine work flow
the mashine needs a point G53 that is always th samwe
we use LIMIT switches on that and REFerence Homeswitches that are triggerd by the mashine moving at start
7 years 4 months ago #137879 by rodw
Generally when this happens (I can't speak for rotary) it is because the torch is at 0,0 and your file takes it into negative X or Y territory. Often this could be as simple as kerf width compensation. The usual solution is to jog away from 0,0 and touch off before cutting. I can't speak for rotary but essentially, its treated as a flattened sheet so I'm guessing the same will apply. You may need to move the torch the width of the kerf (or a touch more) and touch off. But I have no experience with rotary.
7 years 4 months ago #137984 by pl7i92
as e got no wrferencing at all
and the ini showes +-10000mm
i guess simply the VAR did run out as it is always set to the mid point at startup nd counts upwards without reset G54 value
this is within 2.7 <12
7 years 4 months ago #137996 by Surfermann
Thanks. My X axis is left/right movement on the gantry for both rotary and sheet. The error occurred because I have a manual release on my gantry so after I make a cut in tube, left to right, I reposition the torch manually (move right to left). Since I never set home, the amount kept adding up. I hit the home button this morning and the dro read 9999. Reset all and problem solved.
Of concern in my situation, I never home the Y, Z or A (rotary) axis. I will look into the .var files today.
7 years 4 months ago #138053 by andypugh
I would strongly advocate adding home switches and homing at the start of each day.
Time to create page: 0.101 seconds
