Handling large files
7 years 4 months ago - 7 years 4 months ago #138188 by Lezard
Replied by Lezard on topic Handling large files
OK, so I've made some progress on this idea : I've been able to use sampler to read motion.program−line, but the output to a text file still needs some work : halsampler creates the file but it remains empty. I think I might need to close the file at some point, but I still need to figure out when and how to do it. Also, it seems that motion.program−line is actually the count of line processed from the beginning of the session, not from the start of the ngc file ? I still need to double-check to make sure.
On another note, I've experimented with the use of Start-from-line : it works, but in my case, if the spindle was stopped, it won't restart it. I guess this is normal, but this means that I really need some sort of script, maybe run from a button on the UI, to resume the execution of the G-Code with all required pre-commands, so that I won't forget anything important. So the sampler/halsampler might need to store more than just the line number, so that I can create a script that restores proper conditions before resuming the file processing.
More on this later, but I will be away from the machine for some days
Last edit: 7 years 4 months ago by Lezard.
7 years 4 months ago #138190 by lorenzn
Replied by lorenzn on topic Handling large files
Did you set the enable pin?
7 years 4 months ago #138193 by Lezard
I think it is enabled by default, I checked it with HAL monitor (?) and I could see that the pin and associated signal received the expected value. I'm a bit confused by the halsampler doc : it seems that there is no function to activate, just loadusr halsampler ?
7 years 4 months ago #138196 by Grotius
Replied by Grotius on topic Handling large files
I made a short code example for your mars surface log file...
You could integrate this code in a component. Yourhal_line will be your input character text string in this case, could be
a complete g_code line.
#include <stdio.h> #include <stdlib.h> #include <string.h> #include <math.h> char linebuffer[200] = "firstline"; int i; //int main(int argc, char *argv[]){ FILE *file_write=fopen("log.txt", "w"); file_write=fopen("log.txt", "w"); //Yourhal_line = linebuffer; fprintf(file_write,"\n%d\t%s ", i, linebuffer); i++; fclose(file_write); //}
Output :
Good luck !!
The following user(s) said Thank You: chimeno
7 years 4 months ago #138197 by lorenzn
Yes I see you're right it is enabled by default. When I used it, I setp enable 0 in my .hal file, then enabled with halcmd when I was ready to sample the data and write to the file.
loadrt sampler depth=10000 cfg=b addf sampler.0 servo-thread setp sampler.0.enable 0 net 1-is-homed sampler.0.pin.0
Then run
$ halcmd setp sampler.0.enable 1 $ halsampler -t out
7 years 4 months ago #138200 by Lezard
Hi @Grotius,
Thank you very much for your code sample.
I'm really a noob on this so will need some time to figure out what it does/how to use it, but I'm sure it will come handy at some point.
Time to create page: 0.073 seconds
