Linuxcnc wont start own configuration
01 Jul 2019 07:57 #138287 by JB-Motoring
Linuxcnc wont start own configuration was created by JB-Motoring
Hey folks!
I've got a Problem with my System.
Things starte like this: i tried to install Teamviewer, that didn't work.
After that I also couldn't connect to apt-get Servers.
So I took out my Debian 9.9 CD and refreshed the System from Zero.
I installed everything like the time before.
So Debian 9.9 Made it for preempt rt(ethernet mesa Cards)
And then installed Linuxcnc 2.7.14
But now! Linuxcnc wont open up again with my own config.
Examples work, but none of my own configs Do so.
Also there pops no error message Window up.
What could have happened?
Thanks guys!!
  • Moderator
  • Moderator
01 Jul 2019 09:34 #138289 by tommylight
Replied by tommylight on topic Linuxcnc wont start own configuration
Wrong version of Linuxcnc ???
There are a lot of differences between 2.7 and 2.8 in joint/axis setup so that might be one reason.
You need to attach some logs and error mesages, otherwise it is just a guesing game.
The following user(s) said Thank You: JB-Motoring
01 Jul 2019 10:25 #138290 by BigJohnT
Replied by BigJohnT on topic Linuxcnc wont start own configuration
Open a terminal and run your configuration and see if you get an error message there. After attempting to run in a terminal type dmesg to get system messages.
JT
The following user(s) said Thank You: JB-Motoring, cheng
01 Jul 2019 20:32 #138331 by JB-Motoring
Replied by JB-Motoring on topic Linuxcnc wont start own configuration
Thanks guys!
Starting Linuxcnc in terminal showed me the mistake- the mesa's were not connected at that point- little mistake BIIIIG Fault :-D.
Thanks for helping :-))
Time to create page: 0.652 seconds
