Gmoccapy plasma connections
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Jul 2019 05:22 #138591 by phoenix
Gmoccapy plasma connections was created by phoenix
When i try to hook up signals like if i hook up arc ok in signals. Hal
Arc ok led will automatically get vanished from gui
04 Jul 2019 07:12 #138600 by pl7i92
Replied by pl7i92 on topic Gmoccapy plasma connections
hi
the standard Gmoccapy does not suport gui plasma
so what are you connecting this signals to gui pins
you must have a real system overloaded PC as you dayly change the platforms
i am right now at the center programm of the shop
with 3plasmas to the left and 2 to the right also 4 cnc woodmashines in a view meters
all are running on 2.5-2.7 with standard axis
ok it is a production shop no showroom
what im trying to say what are you looking for
a cool looking GUI or a real good runnning mashie
i think you are up to overkill yourself
STAY with AXIS and a pyvcp panel untill the PLASMAC fits your hardware
from install
  • phoenix
  • Premium Member
  • Premium Member
04 Jul 2019 08:08 #138607 by phoenix
Replied by phoenix on topic Gmoccapy plasma connections
Yes sir i got it
For now only axis no gmoccapy :)
I though to move over gmoccapy for I'm having problems with thc toma..
Its goes automatically into feed hold
I create a external realease feed hold but still not working properly
AND JUST ONE MORE QUESTION
IN FEEDCOMP I CONNECT VEL PIN TO MOTION. CURRENT. VEL
BUT I DOESN'T FIND PIN FOR FEED
TO ADD TO FEEDCOMP. 0.FEED
04 Jul 2019 09:07 #138609 by rodw
Replied by rodw on topic Gmoccapy plasma connections
The Gmoccappy plasma screen is just that a screen and there is no connection to anything to run a plasma table. There is a huge amount of work to build a system using Gmoccappy. Islande261 and I have done it but now we have plasmac with a gmocappy screen, it is basically obsolete in my view.
Time to create page: 0.146 seconds
