current feedrate in hal
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Jul 2019 15:48 #138629 by phoenix
current feedrate in hal was created by phoenix
i want to add current feedrate into hal pin
is there any component for current feedrate
i already connected vel pin
im using feedcomp
which parameter needs value of current feed
i want my corner lock signal externally
as thc toma failed now im going to control from external thc
  • Moderator
  • Moderator
04 Jul 2019 20:04 #138641 by tommylight
Replied by tommylight on topic current feedrate in hal
Thc toma never fails.
How do you expect THC to work if you do not have a THC???..
And it does have corner lock that works perfectly.
Time to create page: 0.155 seconds
