Do you have a linuxcnc guide?
- slckzbn
10 Jul 2019 06:10 #138990
by slckzbn
Do you have a linuxcnc guide? was created by slckzbn
I started using linuxcnc new. I did the installation -Debian 9 Stretch -Linuxcnc 2.9.0
How do I make settings for the Delta robot kinematic rotary?
How do I use the settings?
I don't know anything about these issues, is there an initial guide that can help?
- pl7i92
- Thank you received: 358
10 Jul 2019 07:23 #138992
by pl7i92
Replied by pl7i92 on topic Do you have a linuxcnc guide?
hi welcome
under the SIMULATION folder in the START menue there is a delta robot
you can see settings there
then search for delta robot in the forum
unfortenly ther is no grafik setting up for robots
you need to edit th configuration files by hand
HAL and INI files drive the system
you can get infos at the Documentation MASTER
and also at
linuxcnc.org/docs/html/man/man9/
for every module separated
and also at
The following user(s) said Thank You: slckzbn
- Thank you received: 4652
12 Jul 2019 14:04 #139175
Replied by andypugh on topic Do you have a linuxcnc guide?
Also: linuxcnc.org/docs/2.8/html/motion/kinematics.html
And the other docs at : linuxcnc.org/docs/2.8/html/
Note that these are the docs for the 2.8 version, and I would suggest using that version for any non-cartesian machine.
