Making a thc with resume cut button using thcud
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
15 Jul 2019 10:40 - 15 Jul 2019 10:56 #139407 by phoenix
Last edit: 15 Jul 2019 10:56 by tommylight. Reason: removed offending text
15 Jul 2019 18:12 #139487 by Grotius
@Phoenix,
This is in all the year's i see a moderator deleting a text of a forum member.
Here is your solution for your question :
u are saying i do not need to compile plasmac
then how can i get it ???
or i have to wait for next release ??
I think i would go for debian 9 stretch..
linuxcnc.org/downloads/
  • phoenix
  • Premium Member
  • Premium Member
16 Jul 2019 01:02 #139527 by phoenix
Sir i got it from build bot on wheezy thanks for your kind help
Now I'm struggling to make parport connections in that config
I tried loading parellal port using loadrt
But its just not loading parport component
16 Jul 2019 22:10 #139617 by Grotius
@Phoenix,
I have a idea for you !!
You downloaded and installed a dvd or usb install with linux. On your pc are several configuration's.
It has a parport configurator. Fill in the parport configurator as minimal for you. Test output 17 on your board.
If this work's you can add the parport lines step by step in a other configuration. Does not matter wich configuration.
I can add a parport to a mesa hal file, or to a etercat hal file. In linux you can do everything you want. But it takes time to
investegate.
Take your time. In the end. (after a few years) you got ultimate power !!
  • Moderator
  • Moderator
16 Jul 2019 22:36 #139627 by tommylight
Replied by tommylight on topic Making a thc with resume cut button using thcud
That was sooooo ........ hmmmm.....powerfull ! :)
Time to create page: 0.216 seconds
