Plasmac configurator not working
- phoenix
15 Jul 2019 10:32 #139406
by phoenix
Plasmac configurator not working was created by phoenix
Can someone tell me how can i connect step and dir signals inside plasmac.
By using configurator
And what the hell are hal pin for arc ok and voltage and float
If it's not parport pin
And why is isnt starting after configurator
- Dinuka_Shehan
- Thank you received: 26
23 Jul 2019 17:48 #140330
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Plasmac configurator not working
TommYliGht
Ask him,
He is the plasma cut cnc expert.
Ask him,
- Thank you received: 7478
23 Jul 2019 18:05 #140335
He did, in 9 separate threads and we all answered to his questions several times, but he was busy calling us "morons".
Replied by tommylight on topic Plasmac configurator not working
TommYliGht
Ask him,
The following user(s) said Thank You: bevins, phillc54
- Dinuka_Shehan
24 Jul 2019 08:03 #140409
by Dinuka_Shehan
ඔහු වෙන වෙනම නූල් 9 කින් කළ අතර, අපි සියලු දෙනාම ඔහුගේ ප්රශ්නවලට කිහිප වතාවක්ම පිළිතුරු දුන්නෙමු, නමුත් ඔහු කාර්යබහුල වූයේ අපව “මෝඩයන්” ලෙස හැඳින්වීමෙනි.
ඔහුට උදව් කළ සැමට ස්තූතියි!
Thank you for all of who helped him!
- phoenix
11 Aug 2019 03:24 #141890
by phoenix
Replied by phoenix on topic Plasmac configurator not working
I'm not intended to offend any of u but I'm sick of getting same eror again and again its just say parport. 0.pin-8-out doesn't exists
Or plasmac voltage in needs to connected to float in pin and parport doesnt have float in pin
- phillc54
- Thank you received: 2100
11 Aug 2019 06:52 #141895
by phillc54
I am sure that has been answered for you previously more than once.
From the man page for plasmac:
The notes referred to:
Replied by phillc54 on topic Plasmac configurator not working
plasmac.arc-voltage-in
float in arc voltage input [mode 0 & mode 1] see Notes aboveThe notes referred to:
NOTES
- arc-voltage-in is NOT an analog input, it is a floating point number
representing the arc voltage which should be linear. An example would
be the velocity output of an encoder. To set it up at zero volts, use
the actual value of arc-voltage-in as the value for arc-voltage-off‐
set, then apply a known voltage and set arc-voltage scale to known
voltage / arc-voltage-out.Please Log in or Create an account to join the conversation.
- Thank you received: 5325
11 Aug 2019 14:54 #141915
Replied by PCW on topic Plasmac configurator not working
If you used a pre-calibrated analog float value, would you set scale to 1 and offset to 0?
- phillc54
11 Aug 2019 23:22 #141939
by phillc54
I think that is how rodw and islander261 have their settings.
- Thank you received: 4149
12 Aug 2019 09:18 #141955
Yes, Phill had an early bug so we just decoded the torch voltage outside of plasmac and set scale and offset to 0 like we had always done.
Replied by rodw on topic Plasmac configurator not working
- Thank you received: 4654
13 Aug 2019 21:52 #142082
It is parport.0.pin-08-out
Replied by andypugh on topic Plasmac configurator not working
6 bit IN FALSE parport.0.pin-01-out
6 bit IN FALSE parport.0.pin-02-out
6 bit IN FALSE parport.0.pin-03-out
6 bit IN FALSE parport.0.pin-04-out
6 bit IN FALSE parport.0.pin-05-out
6 bit IN FALSE parport.0.pin-06-out
6 bit IN FALSE parport.0.pin-07-out
6 bit IN FALSE parport.0.pin-08-out
6 bit IN FALSE parport.0.pin-09-out
6 bit OUT FALSE parport.0.pin-10-in
6 bit OUT FALSE parport.0.pin-10-in-not
6 bit OUT FALSE parport.0.pin-11-in
6 bit OUT FALSE parport.0.pin-11-in-not
6 bit OUT FALSE parport.0.pin-12-in
6 bit OUT FALSE parport.0.pin-12-in-not
6 bit OUT FALSE parport.0.pin-13-in
6 bit OUT FALSE parport.0.pin-13-in-not
6 bit IN FALSE parport.0.pin-14-out
6 bit OUT FALSE parport.0.pin-15-in
6 bit OUT FALSE parport.0.pin-15-in-not
6 bit IN FALSE parport.0.pin-16-out
6 bit IN FALSE parport.0.pin-17-outPlease Log in or Create an account to join the conversation.
Time to create page: 0.098 seconds
