external manual remote for linuxcnc
15 Jul 2019 13:43 #139424 by happylulux
external manual remote for linuxcnc was created by happylulux
I'm searching to plug an external remote to move manually my cnc, I found this on aliexpress: fr.aliexpress.com/item/32996223161.html?...&transAbTest=ae803_3
I wonder if this is compatible with linuxcnc and if there is a tuto to configure it?
Thanks in advance,
Simon
  • Moderator
  • Moderator
15 Jul 2019 14:28 #139434 by tommylight
Replied by tommylight on topic external manual remote for linuxcnc
Not sure that one will work out of the box, but there are others that do work.
There is the possibility of making that one work also but it would require some programming or a new driver, both not to much complicated to do but do require time.
Plenty of info here:
www.google.com/search?ei=eY0sXaSTFor16QT....gws-wiz.btNmgXVuaEo
