Linear move on axis Y would exceed positive limit...
- vmihalca
- Thank you received: 22
16 Jul 2019 05:36 - 16 Jul 2019 07:12 #139541
by vmihalca
Linear move on axis Y would exceed positive limit... was created by vmihalca
Hi guys,
I had this issue before with Z axis but it was a different issue then.
Here is what happens now:
The home of the Y axis is in the midle of the Y travel, and min=-117, max=117
There are a few things I don’t understand.
Why the Z azis goes past of the Z0 of G54?
Why the commnand at line 26 can be executed successfully in MDI?
I ran this code before, I’ve made a part with it.
Since then I’ve added 4th axis so I had to set the center of rotation.
Here are my config files:
github.com/85vmh/LinuxCncConfigs/tree/master/configs/SyilX7
Last edit: 16 Jul 2019 07:12 by vmihalca.
- Thank you received: 4652
16 Jul 2019 23:52 #139646
Replied by andypugh on topic Linear move on axis Y would exceed positive limit...
Having the X and Z machine zero on the rotary axis isn't actually any help with anything, as it happens.
It might give clearer graphical previews, but I have a feeling that even then the work coordinate origin rather than machine coordinate origin is used.
G-code is basically axis-of-rotation agnostic.
That said, there shouldn't be a problem with your current setup.
If you view the preview from the top, are all the lines inside the bounding box? "Line 26" might be out by a few, I think it ignores blanks and comments when counting.
- cheng
- Thank you received: 9
14 Aug 2019 01:39 #142100
by cheng
Replied by cheng on topic Linear move on axis Y would exceed positive limit...
Hello. I guess you set the length of the z axis too small.
[AXIS_Z]
MIN_LIMIT = -120.0 //Try to make this bigger.
MAX_LIMIT = 240.0 //Try to make this bigger.
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 500.0Please Log in or Create an account to join the conversation.
Time to create page: 0.080 seconds
