linuxcnc simulator on debian buster
- ericg
- Thank you received: 10
17 Jul 2019 12:04 #139683
by ericg
linuxcnc simulator on debian buster was created by ericg
Hi I just did a clean upgrade to debian 10 and want to reinstall linuxcnc simulator, the notes I found to do this don't work as git cannot enter the link.
Is there a later set of instructions that could help?
Eric
Eric
- Thank you received: 7471
17 Jul 2019 12:12 #139684
Replied by tommylight on topic linuxcnc simulator on debian buster
Did you check buildbot.linuxcnc.org ?
- ericg
17 Jul 2019 12:16 #139685
by ericg
Replied by ericg on topic linuxcnc simulator on debian buster
no, I didn't know about it, thanks for the heads up, I'll check it out
- ericg
17 Jul 2019 12:34 #139686
by ericg
I installed the key etc and created the sources.d list file then updated and tried it a couple of times but I get 'Package linuxcnc-sim is not available' regardless of which source I use.
any ideas?
any ideas?
17 Jul 2019 15:32 #139705
No creation, they should be in /etc/apt/sources.list.d/additional-repositories.list
or you create
/etc/apt/sources.list.d/linuxcnc-buildbot.list
and put in the deb links
Update
Install
Use the stretch links, they should work.
Created ?!I installed the key etc and created the sources.d list file then updated and tried it a couple of times but I get 'Package linuxcnc-sim is not available' regardless of which source I use.
any ideas?
or you create
Update
Install
- ericg
17 Jul 2019 23:06 #139739
by ericg
did all this, created linuxcnc-buildbot.list in sources.list.d, added the strech repositories. updated and then did apt install linuxcnc-sim but nothing found, also did an apt-cache search linuxcnc-sim and again nothing found except documents and a uspace component.
Perhaps it has been removed for some reason?
I'll try again in a few days.
- Grotius
- Thank you received: 2349
17 Jul 2019 23:27 - 17 Jul 2019 23:28 #139742
by Grotius
Replied by Grotius on topic linuxcnc simulator on debian buster
You want a reinstall of the simulator... Why?
Have you got git installed? Git cannot enter a link, sounds confusing to me.
What dou you want to achieve with Git? Do you want to compile the simulator from source?
Last edit: 17 Jul 2019 23:28 by Grotius.
- ericg
18 Jul 2019 01:33 #139750
by ericg
I lost the functionality of linuxcnc-sim when I did a clean install (upgrade failed) so I want to reinstall linuxcnc, the notes I found related to using git, but the latest notes regarding buildbot.linuxcnc.org is what I followed. see above posts for result
- Thank you received: 4652
18 Jul 2019 11:55 #139786
Replied by andypugh on topic linuxcnc simulator on debian buster
linuxcnc-sim no longer exists.
linuxcnc-uspace will work with any kernel, and will report "Using POSIX realtime" or "Using POSIX non-realtime"
So just install the uspace version and you should be good to go.
Time to create page: 0.371 seconds
