Lathe Tool Zero
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Jul 2019 13:02 #139795 by Dinuka_Shehan
Lathe Tool Zero was created by Dinuka_Shehan
How Zero out X and Z axis of linux cnc lathe?
18 Jul 2019 14:26 #139810 by Todd Zuercher
Replied by Todd Zuercher on topic Lathe Tool Zero
It can be done with the touch off button (work coordinates) or the tool touch off button (tool offsets), or by using MDI commands to do the same things (read about G10 commands in the G-code section of the manual.)
The following user(s) said Thank You: Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
18 Jul 2019 17:31 #139827 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Lathe Tool Zero
OK,
I will read through and leave a comment if their any difficulties>>>
18 Jul 2019 17:47 #139829 by BigJohnT
Replied by BigJohnT on topic Lathe Tool Zero
This may explain touch off with a lathe.
gnipsel.com/linuxcnc/g-code/lathe02.html
JT
Time to create page: 0.419 seconds
