Sieg KX3. Cannot accurately control spindle speed.
- Roadwins
18 Jul 2019 20:21 #139833
by Roadwins
Sieg KX3. Cannot accurately control spindle speed. was created by Roadwins
I got a KX3 a couple of months ago. Just not getting to really play with it. I have noticed that the spindle speed is not correctly controlled. Even in manual control the spindle speed max is about 3000 rpms and low is about 2000. I was looking thru the files and found an older setup. With that one the max is 3500 rpms and low is about 1000. I have not attempted doing my own setup yet. Any ideas on where this is controlled or where I should start? Also what should I look at to get setting and pins if I want to try a new setup? Breakout board is a cnc4pc C11G.
- pl7i92
- Thank you received: 358
19 Jul 2019 11:50 #139868
by pl7i92
Replied by pl7i92 on topic Sieg KX3. Cannot accurately control spindle speed.
hi
here is the spindle info
linuxcnc.org/docs/html/examples/spindle.html
look into the HAL file of your mashine folder
there shoudt be somthing like
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
net spindle-speed-cmd motion.spindle-speed-out => pwmgen.0.value
net spindle-on motion.spindle-on => pwmgen.0.enable
net spindle-pwm pwmgen.0.pwm => parport.0.pin-09-out
# Set the spindle's top speed in RPM
setp pwmgen.0.scale 3600Please Log in or Create an account to join the conversation.
- Roadwins
19 Jul 2019 17:21 #139902
by Roadwins
Replied by Roadwins on topic Sieg KX3. Cannot accurately control spindle speed.
Thanks Pl7i92
Spent the morning playing with the spindle section of stepconfig and starting to learn how the 4 values relate to each other. I am not quite there but I am getting closer and closer.
Time to create page: 0.081 seconds
