Stepper motor Not rotating freely
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Jul 2019 15:05 #140183 by Dinuka_Shehan
Stepper motor Not rotating freely was created by Dinuka_Shehan
Recently get a Old step syn nema 23(Made in Japan)stepper motor.
One of my nema 23 stepper motor is so tight and cannot swing it with my hand too tight(chucked with 3 jaw chuck and can swing it with hand).I think it will burn my stepper driver with this condition.
I open the covers and check where is the problem.
Bearings are good and inspected my dad who is experienced 30 years of manual all round machinist.
Once I attached the rotor with stator without bearings it binds.
I machined to reduce diameter of rotor few hundreds of mm.
but no 100% good.now it can rotate it by pliers and sometimes with hand.
Can I work with this or should I replace another?
  • Moderator
  • Moderator
22 Jul 2019 15:24 #140187 by tommylight
Replied by tommylight on topic Stepper motor Not rotating freely
No you can not, the stepper motors should not be opened, they will loose the magnetic field while you are getting the rotor out, so it will not have any torque any more.
You can open ONLY the back cover without destroying it.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
22 Jul 2019 15:29 #140190 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Stepper motor Not rotating freely
How to count steps of stepper motor without opened?
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
22 Jul 2019 15:30 #140191 by Dinuka_Shehan
To know 1.8 degree or another one?
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
22 Jul 2019 15:32 #140193 by Dinuka_Shehan
Any technical data or proofs do you have about this?
22 Jul 2019 16:57 #140201 by tecno
Replied by tecno on topic Stepper motor Not rotating freely
Please ask GOOGLE your questions and you will find many answers.
  • Moderator
  • Moderator
22 Jul 2019 17:11 #140202 by tommylight
Yes i do, two motors with no torque.
They are magnetised after they are put together in the factory, so fully assembled.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Jul 2019 17:42 #140328 by Dinuka_Shehan
How to calculate number of steps of stepper motor without removing the covers?
Note there are no label or markings on this motor.
  • Moderator
  • Moderator
23 Jul 2019 18:10 #140337 by tommylight
Attach a 20 to 30 cm stick with glue to its shaft so you can actually measure the angle it moves.
Or make a line in the shaft and body of motor and try to count the steps while slowly rotating the shaft.
The first is more precise the longer the stick.
The following user(s) said Thank You: Dinuka_Shehan
