Beginner question
7 years 3 months ago #140449 by bevins
Replied by bevins on topic Beginner question
Traktor1Tarzan wrote: Servos is really the dream, but with 3 servos and the mesa bords it will be between $1150-1720. And with steppers it will be $400
If i buy boards from mesa site, and motor from aliexpress.
Not sure yet which way to go.
Not really true.
You can get 750Watt ac servos with drives for 170 a set with cables, that's about 500 then 200 mesa go kit, then power supply etc.... 100.
800.00, versus 400 and 10 times better and stronger. Do your self a favor and save up for the servo's. you will regret it if you don't. especially for milling machine.
Just my .314838 cents.
The following user(s) said Thank You: Traktor1Tarzan
7 years 3 months ago #140456 by Todd Zuercher
Replied by Todd Zuercher on topic Beginner question
Also don't forget with steppers you still need a stepper drive between the motor and the Mesa board(s). The price for a cheap Chinese 750w servo from ebay is more like $270.
You could also look at something sort of in between with the new closed loop steppers. A new nema34 motor and drive combo runs around $150.
7 years 3 months ago #140539 by Traktor1Tarzan
Replied by Traktor1Tarzan on topic Beginner question
Thanks for the answers. It makes it a lot easier to make good choices.
Are the servos difificult to tune?
7 years 3 months ago - 7 years 3 months ago #140544 by Todd Zuercher
They can be easy or hard, it depends on a lot of factors. But for the most part tuning a velocity mode servo usually isn't very hard unless there is a problem somewhere. Position mode drives (ones that take step/dir commands like a stepper motor) usually have built in self/auto tuning. (One with only a torque input command are often quite a bit trickier.)
Last edit: 7 years 3 months ago by Todd Zuercher.
Time to create page: 0.206 seconds
