Beginner question
7 years 3 months ago #140237 by Traktor1Tarzan
Replied by Traktor1Tarzan on topic Beginner question
By higher gearing, do you mean the gearing that is provided from the motor and ballscrew interaction?
And would a 750w+ servo need ballscrews thicker than 20mm in diameter?
7 years 3 months ago #140243 by Todd Zuercher
Replied by Todd Zuercher on topic Beginner question
The diameter of the screw needed is often more influenced by it's length and maximum RPM, but load and how it is supported at the ends also factor into it.
For example in an application where a 5mm pitch screw works well with a direct drive step motor, you may want to add a 4:1 belt reduction to use a servo.
The following user(s) said Thank You: Traktor1Tarzan
7 years 3 months ago #140263 by Mike_Eitel
Replied by Mike_Eitel on topic Beginner question
This guy has some good videos over drive dimensioning
Ok, in German...
7 years 3 months ago #140266 by pl7i92
Replied by pl7i92 on topic Beginner question
for steel the frame stiffness is the most to care about
NO Gantry
HARD as STONE
NON Flexing Liniar
therfor most are retrofitting a older MAHO at 1500 USD or simular
7 years 3 months ago #140274 by tommylight
Replied by tommylight on topic Beginner question
pl7i92 wrote: therfor most are retrofitting a older MAHO at 1500 USD or simular
Where ??? Last time a checked a month ago, nothing usable under 6800 Euro!
7 years 3 months ago #140290 by Traktor1Tarzan
Anything simulare to that in Norway costs around 6000usd, if youre lucky. And its probably really worn down. Which is why im building it, but i also do it for the learning experience.
Time to create page: 0.326 seconds
