Planned to Buy a rotary encoder!
- Dinuka_Shehan
- Thank you received: 26
23 Jul 2019 17:33 #140324
by Dinuka_Shehan
Planned to Buy a rotary encoder! was created by Dinuka_Shehan
1pc OMRON 60P Incremental Rotary Encoder 60p/r E6B2-CWZ3E NPN Volt Output
Item Description:
Resolution: 60p/r
Power source: 5-12V DC
Current draw : < 100mA
Shaft: 6mm Dia, 12mm Length
Size: 39mm Dia, 38mm Length
Output signal:A B Z 3 phase rectangular orthogonal pulse circuit NPN type volt output
Output resistance : 2K ohms
Maximum mechanical speed: 6000 R / min
Response frequency: 0-100KHz
Cable length: 2 meter 5-core shielded cable
Package include follow :
Encoder x 1 , Coupling x 1 ,Spannerpa x 1 ,and English Manual
notice :
Vcc: + power, V0: ground ,Connection color is clearly marked on nameplate ,
A B Z 3 phase output must not be directly connected with VCC, otherwise,
will burn the output triode.
Is it good?
Item Description:
Resolution: 60p/r
notice :
Is it good?
- Thank you received: 7471
23 Jul 2019 18:13 #140339
Replied by tommylight on topic Planned to Buy a rotary encoder!
Omron = always good.
The following user(s) said Thank You: Dinuka_Shehan
- Hakan
- Thank you received: 454
23 Jul 2019 18:42 #140340
by Hakan
Replied by Hakan on topic Planned to Buy a rotary encoder!
Omron is good.
Make sure that the interface is exactly what you want/need. The CWZ3E part.
They make the same encoder with several different interfaces.
- Dinuka_Shehan
24 Jul 2019 07:52 #140405
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Planned to Buy a rotary encoder!
My bob is 20kHz can I work with this encoder.
my max rpm 2000
my max rpm 2000
- Dinuka_Shehan
24 Jul 2019 07:55 #140406
by Dinuka_Shehan
- Dinuka_Shehan
24 Jul 2019 07:57 #140407
by Dinuka_Shehan
What should be output configuration of encoder.
I have only 20kHz bob and will encoder need a circuit to filter signal to send bob?
- Thank you received: 4652
28 Jul 2019 17:30 #140819
Replied by andypugh on topic Planned to Buy a rotary encoder!
Voltage Output should work directly to the BoB.
- Dinuka_Shehan
29 Jul 2019 11:05 - 29 Jul 2019 11:12 #140876
by Dinuka_Shehan
what is your encoder?
is it Omron too?
5 to 12 VDC Voltage output
10, 20, 30, 40, 50, 60, 100, 200, 300, 360, 400, 500, 600
E6B2-CWZ3E (resolution) 0.5M
Example: E6B2-CWZ3E 10P/R 0.5M
is it Omron too?
Last edit: 29 Jul 2019 11:12 by Dinuka_Shehan.
- Dinuka_Shehan
29 Jul 2019 11:14 - 29 Jul 2019 11:16 #140878
by Dinuka_Shehan
is it Omron too?
Encoders
www.ia.omron.com/data_pdf/cat/e6b2-c_ds_e_6_1_csm491.pdf?id=487
Omron is good.
is it Omron too?
Encoders
Last edit: 29 Jul 2019 11:16 by Dinuka_Shehan.
Time to create page: 0.378 seconds
