Mesa 7I76 + 7i78 setup questions
26 Jul 2019 21:44 #140690 by calvin.d
Mesa 7I76 + 7i78 setup questions was created by calvin.d
I am hoping someone can help me understand how to setup a 7I76e with a 7i78
I need the 5 extra step generators
can this be connected with the default 7I76e firmware ?
how do I figure out the pin assignment so I can map my Axis to the 7i78 ?
I tried just changing the hal file
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
to increase the number of stepgens, but linuxcnc throws and error.
I think the 7I76 is not detecting the 7I78
any help people could offer would be welcome
Thank You
Calvin
26 Jul 2019 23:08 #140698 by BigJohnT
Replied by BigJohnT on topic Mesa 7I76 + 7i78 setup questions
I'm pretty sure you would need to flash the 7i76e with different firmware, but I'm not seeing a 7i76e 7i76x1 7i78x1 bit file...
JT
27 Jul 2019 00:11 - 27 Jul 2019 13:53 #140703 by PCW
Replied by PCW on topic Mesa 7I76 + 7i78 setup questions
freeby.mesanet.com/7i76e_7i76x1_7i78x1D.bit
Should be close ( Note that the 7I78 only has 4 Step/Dir outputs so you end up with a total of 9 Step generators )
Note: the 7I76E cannot detect the 7I78, the 7I78 is a passive BOB that basically just buffers signals
(and provides an isolated analog spindle interface) The additional hardware (stepgens etc) need to be
built into the 7I76Es FPGA with firmware that matches the 7I78s I/O connections (like the firmware above)
Last edit: 27 Jul 2019 13:53 by PCW. Reason: 7I78 only has 4 step/dir outputs
29 Jul 2019 22:28 #140927 by calvin.d
Replied by calvin.d on topic Mesa 7I76 + 7i78 setup questions
Thank you this is exactly what I needed info wise
Time to create page: 0.158 seconds
