Help newbie with linuxcnc on stepper wizard
- pl7i92
- Thank you received: 358
29 Jul 2019 17:22 #140900
by pl7i92
Replied by pl7i92 on topic Help newbie with linuxcnc on stepper wizard
good price on the part
as tod sugest
1/8 woudt be best for you
1/4 woudt also do but not on the tb6560 available only from tb6600
so it is
8 times the stepper steps per rotation value =8*200 =1600steps/steppermotor Rotation
the pinion got 12 teeth at 0,1571 per teeth a Rotation diameter in Action at 1,8852inch per rotation of the pinion
so it is 1600steps per 1,8852inch = 848.82636steps/inch.
as tod sugest
so it is
- Thank you received: 1472
29 Jul 2019 18:04 - 29 Jul 2019 18:08 #140903
Replied by Todd Zuercher on topic Help newbie with linuxcnc on stepper wizard
The 0.54 you estimated for the revs/inch is (if you want it exact)
The number of teeth on a 1" pinion (20) divided by the number of teeth on your pinion (12). then that number divided by the distance traveled by 1 rev. of the hypothetical 1", 20 tooth pinion (pi or 3.14159). Approximately = 0.5305.
Last edit: 29 Jul 2019 18:08 by Todd Zuercher.
- Carrball05carrball05@
01 Aug 2019 05:29 #141067
by Carrball05carrball05@
Replied by Carrball05carrball05@ on topic Help newbie with linuxcnc on stepper wizard
Sweet thanks a lot guys for the help!! I am trying to get the hang of linuxcnc and when people say that they edit the .ini file I am trying to figure that out also. I am trying to cut something with no THC for now but what do you all think of the post and processor that you all use for no THC?
- Thank you received: 7471
01 Aug 2019 11:50 #141094
Replied by tommylight on topic Help newbie with linuxcnc on stepper wizard
Inkscape with the included gcodetools will do just fine.
Time to create page: 0.306 seconds
