LCNC-2.8 vs LCNC-2.9
  • spma
  • spma's Avatar Topic Author
  • Junior Member
  • Junior Member
04 Aug 2019 11:12 - 04 Aug 2019 11:40 #141322 by spma
LCNC-2.8 vs LCNC-2.9 was created by spma
Hi everyone,
Sorry if this is a silly question but what are the main differences between the 2.8 and 2.9-pre versions that
are currently under development?
I don't understand why there are two releases under development at the same time, plus why does the latter already have
a pre-release and 2.8 still does not?
Also, I've seen a ton of work done on the 2.7 branch after the v2.7.14 release, isn't it stable enough for a new minor release, v2.7.15 maybe?
Thanks in advance!
Simão Amorim
Last edit: 04 Aug 2019 11:40 by spma. Reason: Added 2.7 branch question
04 Aug 2019 11:51 #141324 by rodw
Replied by rodw on topic LCNC-2.8 vs LCNC-2.9
Version 2.8 has been quarantined off for final changes with no feature set changes pending it being packaged to becoming the distribution version which will retire 2.7.
In the meantime, V2.9, the development version is still open for business for new features.
Yes its a bit messy with 3 versions but it will fix itself eventually.
  • spma
  • Junior Member
  • Junior Member
10 Aug 2019 19:08 #141881 by spma
Replied by spma on topic LCNC-2.8 vs LCNC-2.9
Thanks for the explanation rodw! Is there any place where I can find the list of features and changes that happened in each version?
I mean, the docs/NEWS file is 10 years old, even on the master branch...(and so are a lot of files there, which I believe makes them completely outdated, except the files that explain features) I guess some cleanup would be nice on those folders...is anyone already assigned to that matter? Because I wouldn't mind doing some cleanup, I think it would be a good way to start contributing to the project :)
Best regards,
Simão
13 Aug 2019 18:30 #142066 by andypugh
Replied by andypugh on topic LCNC-2.8 vs LCNC-2.9
The 2.7 to 2.8 changes are documented here:
linuxcnc.org/docs/2.8/html/getting-start...dating-linuxcnc.html
The 2.8 to 2.9 changes are very much _not_ documented here:
linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
Though one would expect them to be.
The following user(s) said Thank You: spma
13 Aug 2019 23:20 #142092 by rodw
Wow, the 2.8 changes docs is awesome.
14 Aug 2019 19:20 #142152 by andypugh
No you wouldn't. Deleting the version from the URL gives the current release docs.
To get the master docs you put /devel/ in the version slot:
linuxcnc.org/docs/devel/html/getting-sta...dating-linuxcnc.html
(Though at the time of writing that is a clone of the 2.8 version)
  • spma
  • Junior Member
  • Junior Member
16 Aug 2019 10:05 #142313 by spma
Thanks for the link, I've never noticed that the "updating linuxcnc" pages were actually the changelogs of the released versions.
The name is quite misleading as I thought they were instructions about upgrading the linuxcnc version
Time to create page: 0.098 seconds
