Encoder scall, x axis off 1/16 over 8 foot
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Aug 2019 19:07 #141437 by bevins
Is there a mathematical calculation to correct error over 8 foot. I am just stabbing at it trying to get it exact, but measuring with a piece cut with a tape measure. I know thats not accurate but it is the best I have at the moment.
encoder scale is 3967
05 Aug 2019 19:37 - 05 Aug 2019 19:41 #141441 by PCW
I suspect a tape measure may well have +-1/16" or greater error at 8 feet
(650 PPM) but you can correct the axis motion (or at least match your tape measure)
by changing the scale to:
3967 * 1+(1/1536) ( motion reads short on tape ) or
3967 * 1-(1/1536) ( motion reads long on tape )
(1536 is 96" *16)
Last edit: 05 Aug 2019 19:41 by PCW.
The following user(s) said Thank You: bevins
  • bevins
  • Platinum Member
  • Platinum Member
05 Aug 2019 20:16 #141448 by bevins
Replied by bevins on topic Encoder scall, x axis off 1/16 over 8 foot
Yeah, I got it close enough.
Thanks,
Bob
12 Aug 2019 20:20 #141999 by andypugh
Replied by andypugh on topic Encoder scall, x axis off 1/16 over 8 foot
This shouldn't be a guess. The number should be calculable from encoder / stepper resolution and the mechanical parameters.
  • bevins
  • Platinum Member
  • Platinum Member
12 Aug 2019 23:04 #142007 by bevins
I used came out of the manual for this machine. IT is servo's / rack and pinion, and it was off .y 1/6 over 8 foot.
ITs ok now though. Thanks,
Time to create page: 0.162 seconds
