Bitfile for Mesa 7i92 to use 7i74 on P2
- ak007
07 Aug 2019 08:49 #141593
by ak007
Bitfile for Mesa 7i92 to use 7i74 on P2 was created by ak007
I want to connect 7i74(to use it as 8x SSerial) to P2 on 7i92 and i am unable to locate correct bifile. Someone please point me to right direction.
- Thank you received: 7471
07 Aug 2019 09:56 #141599
Replied by tommylight on topic Bitfile for Mesa 7i92 to use 7i74 on P2
- ak007
07 Aug 2019 10:51 #141608
by ak007
Replied by ak007 on topic Bitfile for Mesa 7i92 to use 7i74 on P2
I already checked the zip file from that link, it does not contain bitfile for only 7i74 connected to P2 on 7i92
07 Aug 2019 10:54 #141609
Use one of the 7i92_7i7n_7i74 bit files.
There is usualy a text file with the same name with pins listed so you can check before flashing if it is what you can use.
- ak007
07 Aug 2019 11:15 #141611
by ak007
i checked 7i92_7i7n_7i74 bitfiles, it connects 7i74 on P1 which is IDC type and i do not have IDC cable. That is why i want to connect to P2
07 Aug 2019 16:02 #141616
What 7i92 do you have, there are 2 or 3 types with different connections ?
- Thank you received: 5321
07 Aug 2019 16:06 #141617
Replied by PCW on topic Bitfile for Mesa 7i92 to use 7i74 on P2
- ak007
07 Aug 2019 16:25 #141620
by ak007
Thanks PCW
Time to create page: 0.661 seconds
